Home > General (L494) > Squeaky wheels/brakes on rotation
Page 2 of 7 <1234567>
Lyonhead
Wales
Aw nooooooooo Big Cry Big Cry sorry to hear that......
Have they taken the correct edge off???? It maybe a question that should be asked??? As I stated, it's now a LR technical advisory fix.
Post #502081 Wed Aug 03 2016 4:04pm
Been-and-dunit
Land Rover did the mod Embarassed
Post #502082 Wed Aug 03 2016 4:21pm
Autobiography
When done properly, it works.
My dealer said different brakes are fitted to HSE and HSE Dynamic vs Autobiography though. Not sure if mod is the same?
Post #502123 Thu Aug 04 2016 6:22am
Johnski
I have a HSE Dynamic (but it is the 2012 L320 model) and I'm pretty sure the brakes are normal ones as in HSE, they definitely aren't Brembo Brakes. John
Post #502139 Thu Aug 04 2016 10:41am
Autobiography
The bulletin says it applies to high performance brakes only which I think would mean Brembo.
Post #502141 Thu Aug 04 2016 11:10am
Autobiography
Scrap that. After a few hundred miles it's squealing again. FFS.
Post #502436 Tue Aug 09 2016 6:25am
Lyonhead
Wales
I'm happy to say that at the moment my brakes are squeal free. Very Happy
But, if it does return Embarassed I will just pass the car back to the Dealership. LR are aware of the fault hence the technical department giving advice for a fix. We have all paid a lot of money for our vehicles and if there's a fault it just needs correcting. My SVR does have the Brembo brakes but I don't know if the squeal problem is isolated to these only.
My Dealership, on my request, even sent me a picture of the brake pad mod they have done. I'll attach a photo. I hope this helps.
Post #502438 Tue Aug 09 2016 6:59am
Autobiography
When did you have the mod? Mine has been a few weeks squeal free before it has started again.
Post #502441 Tue Aug 09 2016 8:01am
Lyonhead
Wales
Had the car back August 3rd, done about 100 miles since. I'm really gutted for you as it is sooooo annoying Evil or Very Mad
I think I have a bit of o.c.d. because any rattle, squeak or noise of any sort that shouldn't be there I have to get rid of.
But as I stated before, LR know of this and just have to sort it. It's clearly a fault on their part as they are providing a fix. At least their not coming back saying "it's a characteristic of the car " Rolling Eyes Rolling Eyes
I did end up having a meeting with The Dealer Principal with various things that needed to be done and he agreed that they would be sorted. He assured me whatever it took the car would come back fixed. In fairness they have met this and in my opinion, at the moment Shocked , all is great with the car.
Just to note my car is currently on 1600 miles, I purchased new April 30th this year, so I know I probably don't cover as much miles as others but whatever the squealing should NOT be there.
Post #502442 Tue Aug 09 2016 8:16am
Netsters
It's getting embarrassing now. I went into the dealers, who basically said they have changed pads and disc on other customer's car and the squeak is there and that JLR don't know what the fix it so will have to wait. Also advised me that they don't have a like for like replacement for me to book the car in to do the other warranty bits like poor DAB reception, sagging seat, rear brake caliper paint fade and distorted front speakers.
Anyone getting any better service from their dealers? Range Rover Sport SVR - Santorini Black
Range Rover Sport Autobiography 2016 Yulong White / black interior - Stealth pack
Ferrari 360 F1 Spider red/cream
Ferrari 348 ts red/cream
BMW M4 Convertible Competion Pack
Post #502460 Tue Aug 09 2016 5:47pm
Been-and-dunit
LR fitted new brake pads and discs to cure squeaking brakes ,40 miles so far so good Whistle
LR would only pay for pads ,but I had to pay for discs and no labour charge
Post #502610 Thu Aug 11 2016 6:15pm
Netsters
They made you pay for discs??? Range Rover Sport SVR - Santorini Black
Post #502905 Mon Aug 15 2016 5:21pm
Been-and-dunit
Yes LR would not pay for the discs, slowly loosing faith in LR Sad
Post #502907 Mon Aug 15 2016 5:57pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Brake Pad Squeek
Brake pads should not squeek or make noise when they are not applied as there should be no contact between the pads and the disc with any force. If they are making a noise with no brake pedal application that tells me there is some binding force preventing the brake pad from being pressed against the disc. This would be either the spring clip holdng the pads in place, the caliper pins seizing or a problem with the piston o'rings not deforming properly under pressure.
Sounds like a brake caliper/caliper component problem not a brake pad problem. That could be a lot more expensive for LR to fix than just brake pads on lots of vehicles.
Putting a shamfer (taking the edge off the pads) if it is the problem might work but what happens down the track when the pad wears and there is no shamfer left - sound like a dodgy fix to me.
Post #503207 Fri Aug 19 2016 10:49am
Meiang
Brake Pad Squeal
Further to my last post. I have had a bad squeel from my 2010 RRS TDV8 brakes since new when coming to a stop or low speed manouvering and using the brakes. The problem went away when I stopped washing the car (about 2 years ago) regularly (washing included the wheels). I now wash it every 3-6 months and the problem has gone away.
Another problem was binding of the rear park brake. If I washed the rear wheels and left them over night without driving the car, they would not release and made a big bang noise when trying to drive off.
Post #503213 Fri Aug 19 2016 12:02pm
