Home > General (L494) > Squeaky wheels/brakes on rotation
Page 5 of 7 <1234567>
nja123
Shortbread...they replaced my disks, it didn't work. Rolling Eyes
I spoke to the boss at my local Indy Land Rover specialist to gauge his opinion...if it was his car he would reject it.
He wouldn't modify my brake pads if I took the car to him in the future, because of liability issues.
Post #505315 Tue Sep 13 2016 5:56pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
nja, how old is your car and what is the mileage? Do you have Brembo's fitted?
Post #505340 Tue Sep 13 2016 7:31pm
nja123
Jim...it was 4 months old when it went in to get fixed, 6500 miles and yes, Brembo.
Post #505343 Tue Sep 13 2016 7:40pm
jim4244
I don't understand why there is now a problem with the Brembo set up on the rear wheels now?
I ran my last L494 RRS Dynamic for 2.5 years covering 28,000. This had Brembo's fitted but I never had any problems with squeaking?
Something must have changed?
Post #505392 Wed Sep 14 2016 8:39am
nja123
Rear? Shocked ....my problem is with the fronts. Exclamation
Post #505393 Wed Sep 14 2016 8:51am
fkarim
Been advised by the service department tghey are fitting "modified brake pads" to cure the brake squeak. Probably same fix as others. Will see if it works when I get the car back. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Post #505419 Wed Sep 14 2016 2:30pm
nja123
Hi fkarim...in my case the modified pads didn't work either, i needed the modified-modified pads Exclamation .....ie. a modified pad with bits cut off Exclamation
I'm sure i'm just a one off Big Cry
Post #505422 Wed Sep 14 2016 2:35pm
RRSman
Shortbread wrote:
Well I had a quick chat with my friendly LR salesman who confirmed that LR have apparently issued a bulletin regarding this squealing brakes issue. Apparently the discs should be replaced.
I am taking this with a pinch of salt, at it is coming from the sales team so maybe BS. Laughing
Anyone else heard about this one?
As per my post above - pads changed twice and discs also changed - squeak came back again!
Post #505427 Wed Sep 14 2016 2:50pm
Autobiography
Mine is in the dealer now.
OK so...since mine has been in before when they fitted the shaved pads, Land Rover have changed the composite of the brake pad but are still saying these need to be shaved.
Post #505430 Wed Sep 14 2016 3:12pm
nja123
Oh...you've got the modified-modified like me!
Post #505434 Wed Sep 14 2016 3:30pm
Autobiography
Yes shaved pads V2
Post #505440 Wed Sep 14 2016 4:01pm
nja123
If you search for 'RRS Brake Squeak 2' in youtube you'll hear mine pre botched pads...it's a characteristic of the car my Censored
Link below:-
Post #505441 Wed Sep 14 2016 4:01pm
jim4244
Mine went in for the day on Thursday, for the 3rd time since I picked the car up in June.
All was fine on the trip home, then the squeal came back on Friday morning. I immediately called the dealership who have now ordered the modified parts from Land Rover. They assure me that this will fix the problem once and for all.
I am starting to loose faith in Lamd Rover and the supplying dealership.......... Sad
Post #505681 Sat Sep 17 2016 9:34am
GJW1
Maybe it is the front left its hard to pinpoint. Mine isn't all the time though only when coming to a stop at slow speed.
Post #505682 Sat Sep 17 2016 9:43am
fkarim
Mine was also only on light braking at slow speeds. Fixed after "modified" pads. For now at least. Only picked up the car yesterday so not sure if the fix will last. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #505696 Sat Sep 17 2016 12:41pm
