Home > General (L494) > Squeaky wheels/brakes on rotation |
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 |
Aw nooooooooo sorry to hear that......
Wed Aug 03 2016 4:04pm |
Been-and-dunit Member Since: 15 May 2016 Location: Burton on trent Posts: 145 |
Land Rover did the mod |
Wed Aug 03 2016 4:21pm |
I have a HSE Dynamic (but it is the 2012 L320 model) and I'm pretty sure the brakes are normal ones as in HSE, they definitely aren't Brembo Brakes. John
Thu Aug 04 2016 10:41am |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 |
The bulletin says it applies to high performance brakes only which I think would mean Brembo. |
Thu Aug 04 2016 11:10am |
Scrap that. After a few hundred miles it's squealing again. FFS. |
Tue Aug 09 2016 6:25am |
I'm happy to say that at the moment my brakes are squeal free.
Tue Aug 09 2016 6:59am |
When did you have the mod? Mine has been a few weeks squeal free before it has started again. |
Tue Aug 09 2016 8:01am |
Had the car back August 3rd, done about 100 miles since. I'm really gutted for you as it is sooooo annoying
Tue Aug 09 2016 8:16am |
Netsters Member Since: 07 Nov 2011 Location: London Posts: 175 |
It's getting embarrassing now. I went into the dealers, who basically said they have changed pads and disc on other customer's car and the squeak is there and that JLR don't know what the fix it so will have to wait. Also advised me that they don't have a like for like replacement for me to book the car in to do the other warranty bits like poor DAB reception, sagging seat, rear brake caliper paint fade and distorted front speakers.
Tue Aug 09 2016 5:47pm |
LR fitted new brake pads and discs to cure squeaking brakes ,40 miles so far so good
Thu Aug 11 2016 6:15pm |
They made you pay for discs??? Range Rover Sport SVR - Santorini Black
Mon Aug 15 2016 5:21pm |
Yes LR would not pay for the discs, slowly loosing faith in LR |
Mon Aug 15 2016 5:57pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 402 |
Brake pads should not squeek or make noise when they are not applied as there should be no contact between the pads and the disc with any force. If they are making a noise with no brake pedal application that tells me there is some binding force preventing the brake pad from being pressed against the disc. This would be either the spring clip holdng the pads in place, the caliper pins seizing or a problem with the piston o'rings not deforming properly under pressure.
Fri Aug 19 2016 10:49am |
Further to my last post. I have had a bad squeel from my 2010 RRS TDV8 brakes since new when coming to a stop or low speed manouvering and using the brakes. The problem went away when I stopped washing the car (about 2 years ago) regularly (washing included the wheels). I now wash it every 3-6 months and the problem has gone away.
Fri Aug 19 2016 12:02pm |
