![]() | Home > General (L494) > Squeaky wheels/brakes on rotation |
Lyonhead Member Since: 21 May 2016 Location: Cardiff Posts: 351 ![]() ![]() |
Hello, I thought I'd give an update after posting photo's and have now completed about 600 miles since the mod has been done by the dealership. I'm happy to report that the brakes are working as they should and there is no squeal at all |
sally Member Since: 01 Sep 2014 Location: out and about Posts: 376 ![]() ![]() |
My SVR developed a squeak at about 6000 miles. I had a brake service, still noisy. I have taken a chance and swapped the pads for EBC redstuff ceramic ones and the noise has gone. So if anyone doesn't fancy having their brembo pads chopped up at the dealer, you have an alternative.
DaveLeeds Member Since: 15 Oct 2015 Location: Leeds Posts: 7 ![]() ![]() ![]() |
I have just taken mine in for a service mentioned the brakes again as have since I have had the car last 12 months, told me there was an upgrade due Happy days !! i thought ! then i get a call saying brakes are 70 % worn and do i want a quote for new pads ???? same guy i booked car in with ?? I mentioned the earlier conversation and he said it was just for normal RRS not the SVR but as a gesture of goodwill he will pay the labor and only charge me £508 for the pads.......
Do you have the part numbers please ?> thanks |
Dave,
Mine is an SVR too mate, Land rover are saying no problem noted only on the other high performance brakes which are smaller than the SVR i will look through your posts
front pads - Ebc redstuff ceramic low dust - part number DP32064C They may make noise until they bed in if you are fitting them on old discs but a decent drive/bed in period and you should be squeak free. i did 6 hours driving on sunday and no noises to report. I think the dealer repair was to grind away a chunk of pad. Thats not really a solution im happy with. Also, my hubby is convinced these pads feel better then the bremos anyway. 2012 Evoque 2014 Sport Autobiography 2015 SVR for the fun stuff 2016 Evoque SI4 Dynamic Lux for the daily drive 2016 Defender 90 2018 SVR |
nja123 Member Since: 03 Jun 2016 Location: UK Posts: 33 ![]() ![]() |
My car developed the same squeak after 1 month of ownership…the car has now been at the dealers for 7 weeks, they have replaced multiple sets of pads (5 in total I think), a couple of sets of disks and they even tried a wheel bearing!. They have driven a total of circa 125 miles during test drives following the various attempts at a fix over a total period 6.5 hours on the road!.
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
From the position of that chamfer I'd suggest the pads are not returning square and so the edge is 'polishing' against the disc. It is quite often that the leading edge of the pads may require a chamfer and some manufacturers do this. Consequently I think JLR have a calliper/hydraulics or alignment issue for such an unusually positioned chamfer to be needed. I'd chamfer the leading edge, check the pads backing is not grooved or lipped and be willing to bet the squeal would go |
About a 1000 miles done now, various driving scenarios of motorway and country roads and happy to say the brakes are performing perfectly and even better, silently.
Sorry, Kwik Fit was the first name that sprang to mind...Halfords??? |
Well folks it's official.....it's a "characteristic of the car" and not a fault and I/we have no grounds for rejecting the vehicle - as I've been informed by JLR UK. It seems to be happy days for them if it happens to more than one car, it's no longer a fault, HOORAY, aren't we lucky!.
I'm sorry but you said that the car developed a squeal after 1 month of ownership, but, you did not say if you bought new or used ( if you bought new clearly you have the high ground for the fault on the car ). Also you state that Land Rover have offered the fix and shaved the edge off, has this stopped the noise??
Thanks Lyonhead...sorry, yes, an important detail..the car was a 3 month old demonstrater bought from a main dealer, so the car was 4 months old when it went in to be fixed.
