![]() | Home > Technical > Wheel arch trim? |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
Anyone know what the lengths are for front and rear for 2009 RRS. Want to replace my missing set but I'm using something like this http://www.ebay.co.uk/itm/231833330630?_tr...EBIDX%3AIT
I'm sure Dan at Duckworths charges a lot less... |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
These are what you want, exactly same as Sport but six pieces and longer will do whole vehicle twice.
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 ![]() ![]() |
Absolutely, I bought those on Cols advice. You just need to cut them to size but if you plan it carefully, as Col says, there will be enough to replace them twice |
Well hope recovery goes well and thanks for the info.. I was only using that ebay item as an example nof what i was looking at (there's 100's of different sizes and shapes) while waiting on measurements to confirm sizes. |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 ![]() ![]() ![]() |
Hi Dan
Like these you mean. ![]() Last edited by Col on Thu Jul 21 2016 12:03am. Edited 1 time in total |
Deleted, please remove. John
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
And just ordered them, thanks Col. |
As Paul said plan the length, measure twice and cut once and there is enough to do whole vehicle twice, as they fall off every couple of years.
ok trims have turned up
Assuming you have Front Mud Flaps then the Fronts are 225mm long and the Rears are 310mm might pay to allow extra couple of mil. to play with. One of the Long one's will do both of the Rears, either one of the Shorter One's will do both Fronts, leaving 1 long and 3 short ones spare for next time, or sell on. |
When mine dropped off I didn't bother replacing as they hold water ect then you get corrosion.
