Home > Technical > Wheel arch trim?
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
Wheel arch trim?
Anyone know what the lengths are for front and rear for 2009 RRS. Want to replace my missing set but I'm using something like this http://www.ebay.co.uk/itm/231833330630?_tr...EBIDX%3AIT
rather than paying out £55+. Just need to know the lengths/dimensions please.
Post #501226 Tue Jul 19 2016 6:17pm
Paddi
First of all the section of that example is too small; needs to be 22mm wide and 10mm thick. The original is not symmetrical like the example but has grips on only one inside face of the channel. The overall lengths are front 90mm and rear 305mm.
Sad I know but stuck at home recovering from shoulder surgery so glad of something to do! 2008 MY Java Black TDV8 HSE
Post #501230 Tue Jul 19 2016 6:50pm
DrRob
I'm sure Dan at Duckworths charges a lot less... Thumbs Up Visitor from fullfatrr.com
Post #501234 Tue Jul 19 2016 7:30pm
These are what you want, exactly same as Sport but six pieces and longer will do whole vehicle twice.
http://www.ebay.co.uk/itm/GENUINE-LAND-ROV...33ae146990
Post #501235 Tue Jul 19 2016 7:50pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Absolutely, I bought those on Cols advice. You just need to cut them to size but if you plan it carefully, as Col says, there will be enough to replace them twice
Post #501238 Tue Jul 19 2016 8:01pm
Danv8
Well hope recovery goes well and thanks for the info..
I was only using that ebay item as an example nof what i was looking at (there's 100's of different sizes and shapes) while waiting on measurements to confirm sizes.
Post #501262 Wed Jul 20 2016 8:53am
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Re Wheel arch Trim
Hi Dan
I would need to look up the part numbers ,but I bought Britpart wheel arch trim for a Freelander which comes in much longer lengths that I then cut and fitted to the Sport.
It was also a lot cheaper and it looks exactly the same as the original.
Jock Thumbs Up
Post #501323 Wed Jul 20 2016 9:24pm
Like these you mean. Laughing
Post #501325 Wed Jul 20 2016 10:25pm
Johnski
Deleted, please remove. John
Post #501326 Wed Jul 20 2016 10:39pm
Johnski
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Bow down Bow down Bow down Bow down Thumbs Up John
Post #501327 Wed Jul 20 2016 10:39pm
Danv8
And just ordered them, thanks Col.
Post #501501 Sat Jul 23 2016 8:59am
As Paul said plan the length, measure twice and cut once and there is enough to do whole vehicle twice, as they fall off every couple of years.
Post #501509 Sat Jul 23 2016 10:42am
Danv8
ok trims have turned up
Just want to double check with anyone the length of the standard front and rear trims, So i can determine which to cut where, (although im guessing its cutting the longest 2) But As mentioned before It's better to measure twice, cut once.
Post #501790 Thu Jul 28 2016 7:30am
Assuming you have Front Mud Flaps then the Fronts are 225mm long and the Rears are 310mm might pay to allow extra couple of mil. to play with. One of the Long one's will do both of the Rears, either one of the Shorter One's will do both Fronts, leaving 1 long and 3 short ones spare for next time, or sell on. Laughing
Post #501793 Thu Jul 28 2016 8:23am
Tyrefitter
When mine dropped off I didn't bother replacing as they hold water ect then you get corrosion.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #501796 Thu Jul 28 2016 11:16am
