Home > Technical > Wheel arch trim? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Never really worked out why they are there, assumed it was protect arch lip from small stones ect. flying off tyre and as they are cheap enough to replace thought might as well.
Thu Jul 28 2016 12:42pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Ok going on your measurements, I have enough to do 3 sets! The 2 shortest LR005165 are 480mm, The 2 middle LR001624 are 520mm The 2 longer LR001623 are 760mm. So in theory 1 long for both rear and 1 shortest will do both front, (yes I have flaps). I can do that twice, that's left me with 2 520mm lengths. Combined front and rear is 535mm so basically they are short by 15mm! Which is 7mm each end just short, I can live with that. I may put the slightly shorter ones on first, keep a second set and sell on a set, after all the originals lasted 7 years before they swelled and fell off. Be interesting to know which part numbers went where on the freelander. Last edited by Danv8 on Thu Jul 28 2016 5:58pm. Edited 1 time in total |
Thu Jul 28 2016 5:50pm |
Hi Paddi,
Thu Jul 28 2016 5:53pm |
I have 2 massive chips about 5p size on my wheel arch lip caused from stones flying off the front tyres, had my trims been in place I would still have paint there now.lol. I have ordered a Hammerite rust pen to treat these areas and then touch them in with touch up pen before I fit them on. |
Thu Jul 28 2016 5:54pm |
