Home > Technical > Wheel arch trim? |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Anyone know what the lengths are for front and rear for 2009 RRS. Want to replace my missing set but I'm using something like this http://www.ebay.co.uk/itm/231833330630?_tr...EBIDX%3AIT
Tue Jul 19 2016 6:17pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
I'm sure Dan at Duckworths charges a lot less... Visitor from fullfatrr.com
Tue Jul 19 2016 7:30pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
These are what you want, exactly same as Sport but six pieces and longer will do whole vehicle twice.
Tue Jul 19 2016 7:50pm |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
Absolutely, I bought those on Cols advice. You just need to cut them to size but if you plan it carefully, as Col says, there will be enough to replace them twice |
Tue Jul 19 2016 8:01pm |
Well hope recovery goes well and thanks for the info.. I was only using that ebay item as an example nof what i was looking at (there's 100's of different sizes and shapes) while waiting on measurements to confirm sizes. |
Wed Jul 20 2016 8:53am |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 |
Hi Dan
Wed Jul 20 2016 9:24pm |
Like these you mean. Last edited by Col on Wed Jul 20 2016 11:03pm. Edited 1 time in total |
Wed Jul 20 2016 10:25pm |
Deleted, please remove. John
Wed Jul 20 2016 10:39pm |
John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
And just ordered them, thanks Col. |
Sat Jul 23 2016 8:59am |
As Paul said plan the length, measure twice and cut once and there is enough to do whole vehicle twice, as they fall off every couple of years.
Sat Jul 23 2016 10:42am |
ok trims have turned up
Thu Jul 28 2016 7:30am |
Assuming you have Front Mud Flaps then the Fronts are 225mm long and the Rears are 310mm might pay to allow extra couple of mil. to play with. One of the Long one's will do both of the Rears, either one of the Shorter One's will do both Fronts, leaving 1 long and 3 short ones spare for next time, or sell on.
Thu Jul 28 2016 8:23am |
When mine dropped off I didn't bother replacing as they hold water ect then you get corrosion.
Thu Jul 28 2016 11:16am |
