![]() | Home > Technical > activation with IIDTOOL BT VERSION for fbh. |
Lonerangerv8 Member Since: 16 Sep 2015 Location: Cheshire Posts: 83 ![]() ![]() ![]() |
Hi Bodsy,
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 ![]() ![]() ![]() |
Ok timed heater option enabled and tested. All worked fine which is great.
On demand heat/vent buttons should be available when engine is off as they are meant to provide heating/ventilation when in the car but without starting the engine.
Thanks fkarim
Try on demand buttons with ignition off too. Turning the radio on and/or touching the screen will bring the screen to life so you can access the timed climate screen. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Tried with ignition off - no change
Sorry, don't know what to suggest now |
Yetiman Member Since: 16 Dec 2015 Location: Tamworth Posts: 25 ![]() ![]() |
Can the FBH help with cold starts and if so how much to activate it ?
You need to pm Bodsy for the remote fbh activation
Yes absolutely it can. Warms up the engine, you just need to remember to switch it on 1/2 hour before you want to go out. Tamworth, I can supply and fit if you're interested. ![]() Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
BiffoBear Member Since: 23 Feb 2016 Location: Bucks Posts: 51 ![]() ![]() |
Hi Bodsy
No problem, will drop you a message after I've had dinner. |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
Guys - sorry for the late resurrection of thread, but I have updated mine on my 2010 tdv8 but I get no option on the touch screen to set the timed climate. Where should it be? Ideally I was hoping I could set it for the same time each morning, by no sure where to access it. Cheers, Steve 2010 TDV8 |
I've answered my own question. All done now. Just need some cold weather.
