![]() | Home > Technical > activation with IIDTOOL BT VERSION for fbh. |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 ![]() ![]() |
http://www.rrsport.co.uk/forum/topic34755.html
Ned Member Since: 25 Jul 2015 Location: London Posts: 100 ![]() ![]() ![]() |
Thanks I have had a look, I have a my12 autobiography just looking for someone to talk me through the activation process once I have connected my IID TOOL to the car. |
There are 3 settings that need to be configured. They are discussed on the thread above and others on the Sport and Discovery forums. From memory they are FBH Call Start, Fuel Burning Heater and Timed Climate. I have sold my MY13 which wasn't much different from MY12 otherwise I would have plugged my IIDTool in and given you the exact values for these settings. I will try anyway: FBH Call Start = Fitted Radio, Fuel Burning Heater = Fitted, Timed Climate = Enabled. Basically you plug the tool in, connect your phone via BT, go to the Car Config menu, select the HVAC ECU/menu and select the appropriate values for these settings and follow the instructions from there. It is very straight forward.
Flaring, big thank you for your knowledge and time thanks very much.👍 |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Hi Ned,
Thanks myfirstrrs
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
https://www.gap-diagnostic.com/faq/
Thanks soooo much disco mickey really helpful top guy . |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 ![]() ![]() ![]() |
If I just wanted to enable the timed climate option do I still need to set all three settings as below?
Lonerangerv8 Member Since: 16 Sep 2015 Location: Cheshire Posts: 83 ![]() ![]() ![]() |
Just thought I would ask as a newbie to RRS.
They all come with it (uk spec diesels anyway) but we can't tell from your profile what car you have. On the rrs2, it is an option. Bodsys Brake Bible
Hi Bodsy,
Yes it will have the FBH fitted, but you can't enable timed climate on that year. You cAn fit a BAS FBHIC to it though. I can supply and fit if interested. |
