![]() | Home > Technical > Help Required, tailgate issue |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Welcome to the forum |
chrisdodds89 Member Since: 22 Aug 2015 Location: Doncaster Posts: 6 ![]() ![]() ![]() |
Thanks Peachy. I will give that ago tomorrow. It used to work intermittently but as now stopped working altogether. At least I can still get in the boot via the full lid |
The switch historically corrodes - approx £20 for a new one |
That's if I get it open hahaha, will let you know how I get on |
Also try pushing your Landrover logo on your keyfob - This is factory set to open the upper tailgate |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Some idiot was frantically pushing the button on the lower part of the tailgate while I was clicking the LR logo on the keyfob from a distance (just to allow him to take his stuff out).
Mine is set to open the full boot lid and now the switch doesnt work I can't put it back to that setting can i? |
Im sure you can - the instructions are in the owners manual |
The owners' manual says "push the LR logo on the keyfob while simultaneously pushing the upper tailgate lid switch". The problem is, it only works if the switch works. Regards etc.,
^^^^^ so without the keyfob - the upper tailgate does not open from the switch - the switch has been replaced & still does not work ? Is there a fuse ? |
Battery dying on iPad - use the search option on the top banner ' tailgate switch ' loads of info - some good - some bad |
Fuse checked OK.
