Home > Technical > Help Required, tailgate issue
chrisdodds89
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
I can open the full boot lid but the button for the glass lid has stopped working. What can I do to open it to replace the switch? Thanks Chris
The car is a 2008 RRS
Post #486881 Sun Feb 07 2016 10:02pm
PEACHY
Welcome to the forum Thumbs Up common issue Big Cry have you tried pushing it down directly above the switch then toggle the keyfob - ( close - open ) - it may release that way - good luck . 16MY Estoril Blue SVR.............
Post #486882 Sun Feb 07 2016 10:15pm
chrisdodds89
Thanks Peachy. I will give that ago tomorrow. It used to work intermittently but as now stopped working altogether. At least I can still get in the boot via the full lid Smile
Post #486883 Sun Feb 07 2016 10:18pm
PEACHY
The switch historically corrodes - approx £20 for a new one Wink 10 minutes to replace - they can be cleaned up but it means braking the rubber seal - IMO better to replace Thumbs Up 16MY Estoril Blue SVR.............
Post #486884 Sun Feb 07 2016 10:20pm
chrisdodds89
That's if I get it open hahaha, will let you know how I get on
Post #486888 Sun Feb 07 2016 10:44pm
PEACHY
Also try pushing your Landrover logo on your keyfob - This is factory set to open the upper tailgate Whistle 16MY Estoril Blue SVR.............
Post #486890 Sun Feb 07 2016 10:56pm
TheWojtek
Some idiot was frantically pushing the button on the lower part of the tailgate while I was clicking the LR logo on the keyfob from a distance (just to allow him to take his stuff out).
This means I can not open the upper part any more, as the keyfob got reprogrammed by the unison of myself and the idiot, and the manual opening does not work (though I have replaced the switch). What are my options regarding setting the keyfob back to opening the upper part of the tailgate? Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #486891 Sun Feb 07 2016 11:05pm
chrisdodds89
Mine is set to open the full boot lid and now the switch doesnt work I can't put it back to that setting can i?
Post #486892 Sun Feb 07 2016 11:07pm
PEACHY
Im sure you can - the instructions are in the owners manual Thumbs Up 16MY Estoril Blue SVR.............
Post #486893 Sun Feb 07 2016 11:16pm
TheWojtek
The owners' manual says "push the LR logo on the keyfob while simultaneously pushing the upper tailgate lid switch". The problem is, it only works if the switch works. Regards etc.,
Wojtek
Post #486894 Sun Feb 07 2016 11:17pm
PEACHY
^^^^^ so without the keyfob - the upper tailgate does not open from the switch - the switch has been replaced & still does not work ? Is there a fuse ? Crying or Very sad 16MY Estoril Blue SVR.............
Post #486896 Sun Feb 07 2016 11:22pm
PEACHY
Battery dying on iPad - use the search option on the top banner ' tailgate switch ' loads of info - some good - some bad Sad ££££ 16MY Estoril Blue SVR.............
Post #486898 Sun Feb 07 2016 11:31pm
TheWojtek
Fuse checked OK.
I've been browsing this search for weeks, seems it's harness replacement time :/ Regards etc.,
Wojtek
Post #486899 Sun Feb 07 2016 11:47pm
