![]() | Home > In Car Electronics > 2010+ headlight turn signal bulbs |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Hi All,
Yes, you need to use resistors. They just need to be wired in parallel with the LEDs (i.e. from the indicator wire to ground). Bear in mind the heat generated by the resistors when you're positioning them (and water ingress on the wirning front also). 50 Ohm resistors are suggested to reduce the heat output. |
I would assume that the rears are sorted and it's just the fronts that need doing. |
Allegedly yes, also to note is that when I put the hazard warning on then everything reverts to normal...
