Home > In Car Electronics > 2010+ headlight turn signal bulbs |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Hi All,
Mon Jan 18 2016 10:26am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Yes, you need to use resistors. They just need to be wired in parallel with the LEDs (i.e. from the indicator wire to ground). Bear in mind the heat generated by the resistors when you're positioning them (and water ingress on the wirning front also). 50 Ohm resistors are suggested to reduce the heat output. Visiting from DISCO3.CO.UK
Mon Jan 18 2016 10:53am |
I would assume that the rears are sorted and it's just the fronts that need doing. Visiting from DISCO3.CO.UK
Mon Jan 18 2016 11:54am |
Allegedly yes, also to note is that when I put the hazard warning on then everything reverts to normal...
Mon Jan 18 2016 11:58am |
