![]() | Home > Technical > Front park aid inactive, no fault shows on the 'secret' menu |
Welcome. |
Rb1980 Member Since: 01 Nov 2015 Location: London Posts: 17 ![]() ![]() |
Hi there! So will the sensors tick as they should ( well the ones that are working)
The inactive message is a good point actually. I guess you'd need to try and listen to them before they shut off. Failing that, faults codes are triggered for any duff sensors.
hi
Not sure if the RRS headlights make a difference (vs D3), but, yes, I assume the connector is still under the headlight. You need diagnostics to see the codes. |
cools, left or right side light? |
Right. |
sorry to be a pain, driver or pass. side? |
No worries - driver's side. |
where can I get a cheap loom? |
A breaker, I guess, but I would think it unlikely that the existing loom can't be repaired. |
yeah im thinking should be a simple enough cut n paste job hopefully..cheers for ya help |
Just make sure it's nice and waterproof (soldered and heat-shrunk etc.) so it doesn't happen again! |
