Home > Technical > Front park aid inactive, no fault shows on the 'secret' menu |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Welcome.
Sun Nov 01 2015 4:24pm |
Rb1980 Member Since: 01 Nov 2015 Location: London Posts: 17 |
Hi there! So will the sensors tick as they should ( well the ones that are working)
Sun Nov 01 2015 5:13pm |
The inactive message is a good point actually. I guess you'd need to try and listen to them before they shut off. Failing that, faults codes are triggered for any duff sensors.
Mon Nov 02 2015 8:43am |
hi
Mon Nov 02 2015 8:46am |
Not sure if the RRS headlights make a difference (vs D3), but, yes, I assume the connector is still under the headlight. You need diagnostics to see the codes. Visiting from DISCO3.CO.UK
Mon Nov 02 2015 9:46am |
cools, left or right side light? |
Mon Nov 02 2015 9:47am |
Right. Visiting from DISCO3.CO.UK
Mon Nov 02 2015 9:51am |
sorry to be a pain, driver or pass. side? |
Mon Nov 02 2015 9:52am |
No worries - driver's side. Visiting from DISCO3.CO.UK
Mon Nov 02 2015 9:54am |
Mon Nov 02 2015 9:55am |
where can I get a cheap loom? |
Mon Nov 02 2015 10:09am |
A breaker, I guess, but I would think it unlikely that the existing loom can't be repaired. Visiting from DISCO3.CO.UK
Mon Nov 02 2015 2:57pm |
yeah im thinking should be a simple enough cut n paste job hopefully..cheers for ya help |
Just make sure it's nice and waterproof (soldered and heat-shrunk etc.) so it doesn't happen again! Visiting from DISCO3.CO.UK
Mon Nov 02 2015 3:00pm |
