![]() | Home > Technical > Hdc fault since changing lower wishbones |
Welcome. |
Oh, and best to fill in your vehicle profile (if you think you have, check you've selected the colour). |
cookie7280 Member Since: 20 Oct 2015 Location: romsey Posts: 5 ![]() ![]() |
I did the wish bones so no alignment yet
It needs a diagnostic tool to calibrate it, but you also need to get the alignment done ASAP. |
is there anyway to physically check the abs sensors or does it need plugging in for this ? |
Needs to be plugged in to read the data from them, but you could check for physical damage to the wiring etc. I think it highly likely that the issue is the SAS and/or alignment though. |
okay thank you I am going to get it plugged in tomorrow and hopefully sorted |
garyd18166 Member Since: 29 May 2015 Location: leeds Posts: 24 ![]() ![]() ![]() |
Hi , i had the same problem, start the car up and do full left lock , and then full right lock, also check brake pad wear sensors...
I have the same problem
The steering angle sensor needs calibrated using a diagnostic machine, not by working the steering lock to lock |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Had the same problem, changed the brake light switch under the dash and all was well again |
A blown brake light bulb can throw an HDC error too. 2012 SDV6 - it's missing a couple of cylinders
I have the new updated LED'S on the rear, |
