Home > Technical > Hdc fault since changing lower wishbones
cookie7280
2007 Range Rover Sport TDV8 HST Orkney Grey
Hi all
I am currently getting a hdc fault followed by special programmes disabled and suspension lowered.
I have tried removing the battery and charging it
This fault has only come in since I have replaced the lower wishbone. Vehicle was fine before this.
Does anyone have any other suggestions to try or does it need plugging in?
Many thanks
David
Post #477724 Sun Oct 25 2015 10:17am
Lost for Words
Welcome. Thumbs Up
Did you have a full alignment after the wishbones were fitted? Was the Steering Angle Sensor (SAS) calibrated (If not, then I highly suspect this is the issue)? Question
Additionally, have you checked stuff like the height and ABS sensor wires that could have been disturbed?
Thumbs Up Visiting from DISCO3.CO.UK
Post #477726 Sun Oct 25 2015 10:37am
Lost for Words
Oh, and best to fill in your vehicle profile (if you think you have, check you've selected the colour). Thumbs Up Visiting from DISCO3.CO.UK
Post #477727 Sun Oct 25 2015 10:38am
cookie7280
I did the wish bones so no alignment yet
And how do I calibrate the steer angle sensor?
Thank you
Post #477728 Sun Oct 25 2015 10:39am
Lost for Words
It needs a diagnostic tool to calibrate it, but you also need to get the alignment done ASAP. Thumbs Up Visiting from DISCO3.CO.UK
Post #477730 Sun Oct 25 2015 10:43am
cookie7280
is there anyway to physically check the abs sensors or does it need plugging in for this ?
Post #477837 Mon Oct 26 2015 12:06pm
Lost for Words
Needs to be plugged in to read the data from them, but you could check for physical damage to the wiring etc. I think it highly likely that the issue is the SAS and/or alignment though. Thumbs Up Visiting from DISCO3.CO.UK
Post #477839 Mon Oct 26 2015 12:14pm
cookie7280
okay thank you I am going to get it plugged in tomorrow and hopefully sorted
Post #477841 Mon Oct 26 2015 12:20pm
garyd18166
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Hi , i had the same problem, start the car up and do full left lock , and then full right lock, also check brake pad wear sensors...
ensure tracking is also set up as well
Post #479838 Sat Nov 14 2015 8:56pm
garyd18166
I have the same problem
changed the battery no joy on that
brake peddle switch no joy
full left and right lock no joy..
next task is the unit under the passenger wheel arch, unplug it and checking for rusty pins...
let me know what your outcome is plz...
garyd18166@googlemail.com
Post #479840 Sat Nov 14 2015 9:01pm
Disco_Mikey
The steering angle sensor needs calibrated using a diagnostic machine, not by working the steering lock to lock Thumbs Up
Post #479843 Sat Nov 14 2015 9:24pm
B9BS X
Had the same problem, changed the brake light switch under the dash and all was well again Laughing RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #480322 Wed Nov 18 2015 6:55pm
A blown brake light bulb can throw an HDC error too. 2012 SDV6 - it's missing a couple of cylinders
Post #480332 Wed Nov 18 2015 7:43pm
garyd18166
I have the new updated LED'S on the rear,
Post #480348 Wed Nov 18 2015 8:58pm
