Home > Technical > Hdc fault since changing lower wishbones |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Welcome.
Sun Oct 25 2015 10:37am |
Oh, and best to fill in your vehicle profile (if you think you have, check you've selected the colour). Visiting from DISCO3.CO.UK
Sun Oct 25 2015 10:38am |
cookie7280 Member Since: 20 Oct 2015 Location: romsey Posts: 5 |
I did the wish bones so no alignment yet
Sun Oct 25 2015 10:39am |
It needs a diagnostic tool to calibrate it, but you also need to get the alignment done ASAP. Visiting from DISCO3.CO.UK
Sun Oct 25 2015 10:43am |
is there anyway to physically check the abs sensors or does it need plugging in for this ? |
Mon Oct 26 2015 12:06pm |
Needs to be plugged in to read the data from them, but you could check for physical damage to the wiring etc. I think it highly likely that the issue is the SAS and/or alignment though. Visiting from DISCO3.CO.UK
Mon Oct 26 2015 12:14pm |
okay thank you I am going to get it plugged in tomorrow and hopefully sorted |
Mon Oct 26 2015 12:20pm |
garyd18166 Member Since: 29 May 2015 Location: leeds Posts: 24 |
Hi , i had the same problem, start the car up and do full left lock , and then full right lock, also check brake pad wear sensors...
Sat Nov 14 2015 8:56pm |
I have the same problem
Sat Nov 14 2015 9:01pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
The steering angle sensor needs calibrated using a diagnostic machine, not by working the steering lock to lock |
Sat Nov 14 2015 9:24pm |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 |
Had the same problem, changed the brake light switch under the dash and all was well again RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Wed Nov 18 2015 6:55pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
A blown brake light bulb can throw an HDC error too. 2012 SDV6 - it's missing a couple of cylinders
Wed Nov 18 2015 7:43pm |
I have the new updated LED'S on the rear, |
Wed Nov 18 2015 8:58pm |
