![]() | Home > Faults & Fixes > Brake Fault |
First thoughts are a faulty brake servo, but the pedal will be rock solid
Simo1976 Member Since: 18 Sep 2014 Location: Kent Posts: 25 ![]() ![]() ![]() |
Hi Disco_Mikey
Have you had recall P017 carried out?
Better get on the blower and ask the question, sounds expensive |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
recall is foc |
Batch Member Since: 30 Aug 2015 Location: Heidelberg Posts: 2 ![]() ![]() ![]() |
Hi Simo1976, Did you get your brake problem fixed? I am having the same issue, i have replaced the master servo and new discs and pads. The problems seems to be getting progressively worse but the mechanic cannot find anything wrong. Thanks |
OK thanks, i will try with LR and will let you know how i get on. If you get any info would be grateful if you could pass it on. |
