Home > Faults & Fixes > Brake Fault
Simo1976
Brake Fault
Hi Guys,
Back with another problem. This time it's the brakes, when stopped on hill / slope etc with brake pedal firmly down the car will roll forward with nothing left in the pedal. Any ideas what it could be? Just had new discs and pads which has not cured it.
Thanks in advance Out and About
Post #468253 Wed Jul 22 2015 2:02pm
Disco_Mikey
First thoughts are a faulty brake servo, but the pedal will be rock solid
If the pedal goes to the floor, and is very soft, it is likely a failed master cylinder, or excessive air in the system
Post #468254 Wed Jul 22 2015 2:29pm
Simo1976
Hi Disco_Mikey
Yeah pedal goes hard not all the way to floor and car just keeps rolling..! Out and About
Post #468255 Wed Jul 22 2015 2:53pm
Disco_Mikey
Have you had recall P017 carried out?
It may be worth getting in touch with LRCC, they have been known to carry out the recall again, replacing all the items this time round Thumbs Up
Post #468256 Wed Jul 22 2015 2:54pm
Simo1976
Better get on the blower and ask the question, sounds expensive Thumbs Up Out and About
Post #468258 Wed Jul 22 2015 2:58pm
panda
recall is foc Very Happy Very Happy
Post #468265 Wed Jul 22 2015 4:59pm
Batch
Germany 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Hi Simo1976, Did you get your brake problem fixed? I am having the same issue, i have replaced the master servo and new discs and pads. The problems seems to be getting progressively worse but the mechanic cannot find anything wrong. Thanks
Post #471461 Sun Aug 30 2015 4:17pm
Simo1976
Not yet haven't had time to get it looked at. Was going to try in the next few weeks. Servo was mentioned though, and I spoke to LR the only outstanding issue was something to do with a tow bar recall...! Out and About
Post #471469 Sun Aug 30 2015 5:36pm
Batch
OK thanks, i will try with LR and will let you know how i get on. If you get any info would be grateful if you could pass it on.
Post #471474 Sun Aug 30 2015 7:01pm
