Home > Faults & Fixes > Brake Fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
First thoughts are a faulty brake servo, but the pedal will be rock solid
Wed Jul 22 2015 2:29pm |
Simo1976 Member Since: 18 Sep 2014 Location: Kent Posts: 25 |
Hi Disco_Mikey
Wed Jul 22 2015 2:53pm |
Have you had recall P017 carried out?
Wed Jul 22 2015 2:54pm |
Better get on the blower and ask the question, sounds expensive Out and About |
Wed Jul 22 2015 2:58pm |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
recall is foc
Wed Jul 22 2015 4:59pm |
Batch Member Since: 30 Aug 2015 Location: Heidelberg Posts: 2 |
Hi Simo1976, Did you get your brake problem fixed? I am having the same issue, i have replaced the master servo and new discs and pads. The problems seems to be getting progressively worse but the mechanic cannot find anything wrong. Thanks |
Sun Aug 30 2015 4:17pm |
Sun Aug 30 2015 5:36pm |
OK thanks, i will try with LR and will let you know how i get on. If you get any info would be grateful if you could pass it on. |
Sun Aug 30 2015 7:01pm |
