![]() | Home > Technical > Metal weights under rear bumper ? why ? |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Stop Travel sickness |
roscopcoltrane Member Since: 31 May 2013 Location: Scotland Posts: 86 ![]() ![]() |
Harmonic Mass Dampers |
TDV8_AutoB Member Since: 03 Jul 2015 Location: Berkshire Posts: 35 ![]() ![]() ![]() |
Nice - what genius decided that they would be a good idea ? I wonder how much they weigh ? Clearly got to have some effect on economy.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Don't take them off. |
Yes. Leave alone. LR put them there for a reason |
Thanks for the advise guys - much appreciated, will leave them alone. |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
are you sure a RRSport is the right car for you if your worrying about economy ![]() |
Nah - not worrying about economy at all. It's better than the RS6 for sure. Just wondered what the heck they're for - now I know - but certainly they will effect economy, just like driving an aerodynamic brick also does.
Any weight will affect economy, but when you consider the weight of the chassis and the rest of the vehicle, it pales into insignificance! Visiting from DISCO3.CO.UK
Mr Messy Member Since: 14 Jun 2015 Location: Reading Posts: 22 ![]() ![]() ![]() |
I used to be a helicopter technician and we used something similar in the nose to reduce harmonics, pimimtive but effective.
Brilliant - you should work for JLR ! That'll save them a fortune |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
That's Assuming Nobody's already nicked it of course. ![]() Cheers Col |
Mr Messy
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 ![]() ![]() |
I worked on Westland Lynx for 15 years and the vibration absorber on top of the Main Rotor Head had to be tuned using a series of extra circular rings you bolted under the top cover. Used to love doing that job, we called it 'Bonk Testing' as you attached a piece of electrical kit to the vibration absorber to take the measurements and then 'bonked' it on the side with your hand. |
