Home > General (L494) > Heated mirrors |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
I'm going to guess , press the heated rear window button and see what happens . |
Sun May 31 2015 6:02pm |
Nowaytk Member Since: 27 May 2013 Location: London Posts: 183 |
I thought they came on automatically depending on temperature, although not 100% on this. 2015 HSE SDV6 Scotia Grey, ebony / lunar, colour coded, deployable steps, TV, sliding pano and a few other bits. Now gone
Sun May 31 2015 6:53pm |
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 |
I believe they do come on if the temperature is lower than 5C. AFAIK they should also come on if the front wipers are on constantly and/or the rear screen demister is on. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more...
Sun May 31 2015 8:19pm |
scriv Member Since: 28 Jul 2012 Location: kent Posts: 93 |
Thanks for your response
Sun May 31 2015 8:23pm |
Carlo Member Since: 30 Apr 2015 Location: Cardiff Posts: 35 |
Scriv, did you get them to work, having same issue, front and rear heated window switch not doing much |
Fri Jun 19 2015 8:25pm |
Yes all sorted mine do seem to work when the rear heated screen is switched on |
Fri Jun 19 2015 8:34pm |
IIRC (I'm only 6000 miles away from my car at the moment!) the heaters will also come on if you press the MAX button on the heating and ventilation controls - the button that does the rapid defrost and warm up in the winter. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jun 19 2015 10:33pm |
