![]() | Home > General (L494) > Heated mirrors |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 ![]() ![]() |
I'm going to guess , press the heated rear window button and see what happens . |
Nowaytk Member Since: 27 May 2013 Location: London Posts: 183 ![]() ![]() |
I thought they came on automatically depending on temperature, although not 100% on this. 2015 HSE SDV6 Scotia Grey, ebony / lunar, colour coded, deployable steps, TV, sliding pano and a few other bits. Now gone
Chrisr1806 Member Since: 23 Jun 2013 Location: Sussex Posts: 683 ![]() ![]() |
I believe they do come on if the temperature is lower than 5C. AFAIK they should also come on if the front wipers are on constantly and/or the rear screen demister is on. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... |
scriv Member Since: 28 Jul 2012 Location: kent Posts: 93 ![]() ![]() ![]() |
Thanks for your response
Carlo Member Since: 30 Apr 2015 Location: Cardiff Posts: 35 ![]() |
Scriv, did you get them to work, having same issue, front and rear heated window switch not doing much |
Yes all sorted mine do seem to work when the rear heated screen is switched on |
IIRC (I'm only 6000 miles away from my car at the moment!) the heaters will also come on if you press the MAX button on the heating and ventilation controls - the button that does the rapid defrost and warm up in the winter. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
