Home > General > Where to get fault codes read? Engine System Fault
PHinett
Have had the Engine System Fault message flash up a few times now over the past week, switching the car off/on again seemed to sort it out for a few days / trips.
However today it happened again and i seemed to have had less power than usual, i was 100 yards from my house so drove slowly and parked up.
I've been reading through the forums and it seems it could be anything from egr valves, a stuck turbo actuator, or even a stuffed turbo which i'm hoping not.
Can anyone recommend somewhere in the west midlands to read any fault codes stored? First time I have had to do this so what sort of price should I expect to pay for this too?
3.6 TDV8 - 2007 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps Smile
Post #460302 Thu Apr 23 2015 11:03pm
PEACHY
Try here Thumbs Up
http://www.rrsport.co.uk/forum/topic39506.html
Always looked after me - tell Kam or one of his colleagues your from the forum & your looking for free diagnosis & a price if needed Whistle 16MY Estoril Blue SVR.............
Post #460308 Fri Apr 24 2015 7:21am
PHinett
Perfect i'm in Solihull today anyway. Thanks peachy! 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps Smile
Post #460312 Fri Apr 24 2015 8:22am
PHinett
Can't get a diagnostics done until next Wednesday...so in the meantime I had a mechanic friend take a quick look to see if anything was obvious.
He noticed something straight away, a failed O ring on the pipe from the EGR valve to the intake manifold has failed. You could feel the air coming out of it and it was making a hissing sound.
He's pretty certain this is the culprit, said it would explain my low mpg too (currently around 18mpg on the screen).
Next question is where would i get this part from? Would land rover supply it or is there another source? Any idea of a part number or what to search for?
Thank You. 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps Smile
Post #460382 Fri Apr 24 2015 11:41pm
flack
From the sound of it you have had the egr's blanked and they have removed the pipes and put the aluminum blanks in the throttle housing, if so just remove the blank and get a new o'ring for it and make sure you tighten the bolts up equally, as these are known to leak if not fitted correctly.
Flack Thumbs Up
Post #460393 Sat Apr 25 2015 9:14am
PHinett
Thanks for the reply flack.
I'm not aware if it has already been blanked, possibly by a previous owner but it wasn't mentioned on sale.
I have taken a couple of photos of the area to see if anybody can make more sense of it.
I have ordered the O ring from land rover anyway, pick it up tomorrow. £1.25, was expecting £20 or so knowing land rover.
Drivers side (seems to be ok)
(Passenger side - air escaping)
My friend suggested that the issue may have been there before i had the car because the metal plate is screwed tight. 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps Smile
Post #460575 Mon Apr 27 2015 11:22am
