Home > General > Where to get fault codes read? Engine System Fault |
PHinett Member Since: 21 May 2014 Location: Birmingham Posts: 63 |
Have had the Engine System Fault message flash up a few times now over the past week, switching the car off/on again seemed to sort it out for a few days / trips.
Thu Apr 23 2015 10:03pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Try here
Fri Apr 24 2015 6:21am |
Perfect i'm in Solihull today anyway. Thanks peachy! 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps |
Fri Apr 24 2015 7:22am |
Can't get a diagnostics done until next Wednesday...so in the meantime I had a mechanic friend take a quick look to see if anything was obvious.
Fri Apr 24 2015 10:41pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
From the sound of it you have had the egr's blanked and they have removed the pipes and put the aluminum blanks in the throttle housing, if so just remove the blank and get a new o'ring for it and make sure you tighten the bolts up equally, as these are known to leak if not fitted correctly.
Sat Apr 25 2015 8:14am |
Thanks for the reply flack.
Mon Apr 27 2015 10:22am |
