![]() | Home > General > Roof running strips |
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 ![]() |
Can anybody help with this? |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 ![]() ![]() ![]() |
I think they are not designed to take off once they are fitted.....
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
The cover strips are available from dealers. I replaced them on a FL2 when I removed the roof rails to fit on replacement |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
The Weatherstrips as L/R call them are about £60 each with vat. Dan at Duckworth's can probably do better.
Thanks for the replies |
Here you go
Cheers Col that looks ok they don't stand out too much at all. Nice motor by the way those are the wheels I want in 22" along with either the HST or the Autobiography kit. I have already booked in for some exhaust modifications on mine and I am looking at the mudtech 4x4 kit also. |
Williamsboy Member Since: 31 Dec 2014 Location: south wales Posts: 44 ![]() ![]() ![]() |
Hi Mate, My weather strips are the original ones fitted to the RRS and has black grommits in the holes from the factory. i removed one recently to have a look and they push directly into the bolt holes in the roof. Apparently some RRs had the holes from new and other had to drill the holes in order to fit their roof rails etc.
Ok that's good to know as if I do decide to remove the side bars I can just get some rubber gromits instead of buying 2 new running strips, I would imagine they need to be ones that either go in to or over the screw points on the roof to hold them in place. Thanks for that |
When the roof rails are fitted you need to increase the size of the hole in the strip to 19mm in diameter. Hence if you remove the rail the original "Fir Trees" will not retain the strip as the head is to small for the hole so you would need new "Fir Trees" with a head diameter of at least 25mm to retain the strips simply putting a grommet in may well fill the hole but will not retain the strip.
