![]() | Home > Technical > Engine management light |
steve r Member Since: 30 Jul 2014 Location: ESSEX Posts: 19 ![]() ![]() ![]() |
Hi guys, the engine management light has just come on, on my RRS HSE diesel. In the book it says, petrol engines check engine, and underneath it says about emissions. Is this regarding the diesel engine or does it mean i still need an engine check.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
It will be a faulty EGR valve |
Thanks Mikey, will it need changing straight away, or can i leave it until the next MOT about 4 months.
It would be prudent to have it changed at the earliest opportunity, in case the 2nd valve fails, leaving you stranded |
Thanks again Mikey, is it a home job or garage.
With a bit of practice, the valves are about an hour a side. Nothing difficult, but a bit fiddly |
Thanks again Mikey, thank god for people like you. I'll have a look and see what I think.
Needs plugged in and the live values of the EGRs checked, to determine which one is at fault
My thoughts exactly Mikey, so I think I'll do both of them. It's a bit of a lay out, but needs must.
I assume that as the EML came on your car is an 2007, 08, or 09. a Euro 4 spec. Have you thought about blanking the egr valves |
Hello SRE would or could this damage the engine. |
Just thought I'd let you guys know that you can't blank off the EGR valves on an 09 plate, as It only works on tdv6 up to chassis number A6 and not EU4.
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
EU4 blanking available here - https://secure.bellautoservices.co.uk/stor...-20072009/ |
Be aware that the emulators are not as easy as it's made out to be.
Thanks guys. I'm going for the EGR delete and remap. That way it will sort out the EGR valves and give more bhp and torque.
