Home > Technical > Engine management light
steve r
United Kingdom 2009 Range Rover Sport TDV6 HSE Java Black
Hi guys, the engine management light has just come on, on my RRS HSE diesel. In the book it says, petrol engines check engine, and underneath it says about emissions. Is this regarding the diesel engine or does it mean i still need an engine check.
Or can i e=wait to get the emissions done on the next MOT.
Atb, Steve.
Post #453291 Sat Feb 21 2015 4:24pm
Disco_Mikey
It will be a faulty EGR valve Thumbs Up
Post #453298 Sat Feb 21 2015 5:12pm
steve r
Thanks Mikey, will it need changing straight away, or can i leave it until the next MOT about 4 months.
Your help is appreciated.
Atb, Steve.
Post #453408 Sun Feb 22 2015 4:05pm
Disco_Mikey
It would be prudent to have it changed at the earliest opportunity, in case the 2nd valve fails, leaving you stranded
Post #453409 Sun Feb 22 2015 4:06pm
steve r
Thanks again Mikey, is it a home job or garage.
Atb, Steve.
Post #453410 Sun Feb 22 2015 4:49pm
Disco_Mikey
With a bit of practice, the valves are about an hour a side. Nothing difficult, but a bit fiddly
Post #453414 Sun Feb 22 2015 5:12pm
steve r
Thanks again Mikey, thank god for people like you. I'll have a look and see what I think.
Is there any way of knowing if It's the left or right side that is faulty. Or would you recommend changing both.
Atb, Steve.
Post #453419 Sun Feb 22 2015 5:28pm
Disco_Mikey
Needs plugged in and the live values of the EGRs checked, to determine which one is at fault
There is the school of thought, that says if one has gone, the other is probably not far behind it... Not particularly cheap at £140 each though...
Post #453428 Sun Feb 22 2015 6:41pm
steve r
My thoughts exactly Mikey, so I think I'll do both of them. It's a bit of a lay out, but needs must.
Thanks for all your help, as said it's appreciated. i'll let you know how I get on.
Atb, Steve.
Post #453430 Sun Feb 22 2015 6:59pm
SRE
Spain
I assume that as the EML came on your car is an 2007, 08, or 09. a Euro 4 spec. Have you thought about blanking the egr valves Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #453469 Mon Feb 23 2015 8:34am
steve r
Hello SRE would or could this damage the engine.
Post #453517 Mon Feb 23 2015 1:54pm
steve r
Just thought I'd let you guys know that you can't blank off the EGR valves on an 09 plate, as It only works on tdv6 up to chassis number A6 and not EU4.
Atb, Steve.
Post #453887 Thu Feb 26 2015 11:44am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
EU4 blanking available here - https://secure.bellautoservices.co.uk/stor...-20072009/ Thumbs Up
Post #453888 Thu Feb 26 2015 11:49am
Disco_Mikey
Be aware that the emulators are not as easy as it's made out to be.
You have to buy and fit the emulators, but the will not work correctly without the engine management system being updated with some modified firmware...
Post #453974 Thu Feb 26 2015 9:10pm
steve r
Thanks guys. I'm going for the EGR delete and remap. That way it will sort out the EGR valves and give more bhp and torque.
Hopefully I should have the car done within the week Thumbs Up
I'll get the remap readout up when I've had it done so you can see the improvements.
Atb, Steve.
Post #454108 Sat Feb 28 2015 12:38pm
