Home > Maintenance & Modifications > D3 ARB bush replacement same on RRS?
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hey guys!
After reading the most excellent guides by Disco Mikey and Ridgeback Moor several times, I'm gonna do my own bush replacement!
I just want to check....is the procedure the same on their D3 "How to" guide as doing it on a 2007 RRS?
Would love to hear from the RRS guys who have done this procedure.
Gaz.
Post #451901 Mon Feb 09 2015 4:44pm
Gaz
I've cracked on and ordered my updated thicker bottomed bushes!....oo-er!
Post #452058 Tue Feb 10 2015 3:24pm
flack
Have you checked to see if you have normal suspension or the active suspension?. as they are totally different.
Flack Thumbs Up
Post #452095 Tue Feb 10 2015 5:37pm
Gaz
Hi Flack!
Hopefully yes.
I gave them my registration and they checked on the computer.
I have DR and DSC.
He said I have ACE as I have a 2007 HSE. Thumbs Up
Sound correct?....I can always send them back I guess.
Thanks for coming on the thread. Thumbs Up
Gaz.
Post #452108 Tue Feb 10 2015 6:05pm
flack
If you active suspension then the ARB's are not a straight forward job as on the D3, to do the fronts you need to remove the front prop shaft to the front axle to get access to the bush on the right hand side ..
Flack Thumbs Up
Post #452109 Tue Feb 10 2015 6:12pm
Gaz
....oh no!....(gulp)....I've just been put off now.
I was hoping that it was the same as the D3 guide the guys have done.
Gaz.
Post #452110 Tue Feb 10 2015 6:15pm
flack
Nope its a lot bigger job, and the bolts are a pig if they have been rounded off like the last one I did Shocked
Flack Thumbs Up
Post #452112 Tue Feb 10 2015 6:17pm
Gaz
How can I tell if it's gonna be a pig Flack?
Will I not be able to see both both bushes on the front?
I've had a look and thought I could see both.
Post #452114 Tue Feb 10 2015 6:20pm
Gaz
I've been trying to find a RRS guide but can't seem to find one.
Post #452115 Tue Feb 10 2015 6:22pm
flack
The bushes on the active are in a different position on the anti roll bar, it's driven by hydraulics, so the bushes and clamps are bigger, are you sure you have this suspension, do you have a extra pump on the aux belt ?.
Flack Thumbs Up
Post #452117 Tue Feb 10 2015 6:24pm
flack
http://www.car-engineer.com/range-rover-sp...echnology/
Read This
Flack
Post #452119 Tue Feb 10 2015 6:29pm
Gaz
.....crumbs....now you're asking!
Is it not as simple as knowing what year your vehicle is and what model?
What would be the standard on a 2007 2.7 TDV6 HSE?
Post #452121 Tue Feb 10 2015 6:30pm
flack
If its an HSE which is the last model I did then it will have the active on it, not the same as dumb anti roll bar design as on other sports and the D3 and D4.
Flack Very Happy
Post #452123 Tue Feb 10 2015 6:33pm
Gaz
I think I may of bitten off more than I can chew mate!!
Maybe a garage job I think.
I really fancied getting the spanners out!
Gotta know your limitations and not be a hero! Thumbs Up Bow down
Post #452126 Tue Feb 10 2015 6:38pm
Gaz
From what I've read, it can be confusing.
ACE is what was used as a predecessor to DR which is a newer evolved version of it.
In some manuals, they still use the term ACE to describe what essentially is DR on later vehicles.
Hopefully this is true and someone will correct me if I'm wrong!
I know the two different terms being used together confused me!
Post #452129 Tue Feb 10 2015 7:09pm
