Home > Maintenance & Modifications > D3 ARB bush replacement same on RRS? |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
I've cracked on and ordered my updated thicker bottomed bushes!....oo-er! |
Tue Feb 10 2015 3:24pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Have you checked to see if you have normal suspension or the active suspension?. as they are totally different.
Tue Feb 10 2015 5:37pm |
Hi Flack!
Tue Feb 10 2015 6:05pm |
If you active suspension then the ARB's are not a straight forward job as on the D3, to do the fronts you need to remove the front prop shaft to the front axle to get access to the bush on the right hand side ..
Tue Feb 10 2015 6:12pm |
....oh no!....(gulp)....I've just been put off now.
Tue Feb 10 2015 6:15pm |
Nope its a lot bigger job, and the bolts are a pig if they have been rounded off like the last one I did
Tue Feb 10 2015 6:17pm |
How can I tell if it's gonna be a pig Flack?
Tue Feb 10 2015 6:20pm |
I've been trying to find a RRS guide but can't seem to find one. |
Tue Feb 10 2015 6:22pm |
The bushes on the active are in a different position on the anti roll bar, it's driven by hydraulics, so the bushes and clamps are bigger, are you sure you have this suspension, do you have a extra pump on the aux belt ?.
Tue Feb 10 2015 6:24pm |
http://www.car-engineer.com/range-rover-sp...echnology/
Tue Feb 10 2015 6:29pm |
.....crumbs....now you're asking!
Tue Feb 10 2015 6:30pm |
If its an HSE which is the last model I did then it will have the active on it, not the same as dumb anti roll bar design as on other sports and the D3 and D4.
Tue Feb 10 2015 6:33pm |
I think I may of bitten off more than I can chew mate!!
Tue Feb 10 2015 6:38pm |
From what I've read, it can be confusing.
Tue Feb 10 2015 7:09pm |
