Home > Maintenance & Modifications > D3 ARB bush replacement same on RRS? |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
Has anyone on here done a write up on doing a bush replacement on a 2.7 RRS? |
Tue Feb 10 2015 7:45pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Gaz send me your vin number and I can check it for you..
Tue Feb 10 2015 7:54pm |
Legend!.....thanks Flack!
Tue Feb 10 2015 8:00pm |
Gaz its Active on your sport
Tue Feb 10 2015 8:20pm |
......okay....so,
Tue Feb 10 2015 8:40pm |
No both back and front are not as easy if you just had the dumb anti roll bar..
Tue Feb 10 2015 8:43pm |
I've searched and searched but I just cannot find a how to guide on this particular type of bush change. |
Tue Feb 10 2015 9:01pm |
Thats because you really need a ramp to change this type of bush and its not an easy DIY job..
Tue Feb 10 2015 9:12pm |
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 |
I have to agree with Flack. Did my front active RRS bushes today - 6 Hours. Left side needs propshaft undoing and tying out of way which gives you about 2 inches to play with. Right side has active bar hydraulic lines right in way as well. You can't get a socket on ANY of the 6 bolts!! Even with bolts out getting the drivers side bush in is next to impossible! If you were brave would have been made easier by disconnecting hydraulics to bar to remove these pipes but there's obviously risk of ingress of dirt etc so I left those well alone.
Mon May 18 2015 9:54pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Hi when you say...
Sun Sep 06 2015 12:19am |
Remove bolts in propshaft flange and yes mark where it originally went to be sure it goes back in the same place. Bit of a faff as I recall having to turn the shaft to get to all the bolts. Eg lots of gearbox changing from P to N etc but otherwise it's straightforward. It will probably be stuck with all bolts out so a small blow should do the trick. I would recommend new bolts on reassembly however. Good luck! 3.0 SDV6 HSE L494 |
Sun Sep 06 2015 9:31am |
cookie7280 Member Since: 20 Oct 2015 Location: romsey Posts: 5 |
hi I aim attempting this on my vehicle I have removed the 6 bolts but cannot get the prop to realease. does it just need tapping back? it is almost like there is weight on the drive still? |
Tue Oct 20 2015 9:47am |
