![]() | Home > Maintenance & Modifications > D3 ARB bush replacement same on RRS? |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
I've cracked on and ordered my updated thicker bottomed bushes!....oo-er! |
Have you checked to see if you have normal suspension or the active suspension?. as they are totally different.
Hi Flack!
If you active suspension then the ARB's are not a straight forward job as on the D3, to do the fronts you need to remove the front prop shaft to the front axle to get access to the bush on the right hand side ..
....oh no!....(gulp)....I've just been put off now.
Nope its a lot bigger job, and the bolts are a pig if they have been rounded off like the last one I did |
How can I tell if it's gonna be a pig Flack?
I've been trying to find a RRS guide but can't seem to find one. |
The bushes on the active are in a different position on the anti roll bar, it's driven by hydraulics, so the bushes and clamps are bigger, are you sure you have this suspension, do you have a extra pump on the aux belt ?.
http://www.car-engineer.com/range-rover-sp...echnology/
.....crumbs....now you're asking!
If its an HSE which is the last model I did then it will have the active on it, not the same as dumb anti roll bar design as on other sports and the D3 and D4.
I think I may of bitten off more than I can chew mate!!
From what I've read, it can be confusing.
