![]() | Home > General > Crankshaft Seal leaking -looking at £2,500 to repair!! |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
All I can say is |
Get a second opinion from an independent. Wouldn't be surprised if the oil is coming from somewhere else. Land Rover dealer's diagnostic skills are questionable. 2008 MY Java Black TDV8 HSE
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 ![]() ![]() ![]() |
They say they have already stripped the engine to find out it was a crankshaft leak and that there would be additional cost to put it back where it was.
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Be prepared to argue your case with Warranty Direct, as they needed to be informed of the leak before ANY work was done, I have had the same issue with them over another oil leak, they also keep you going round in circles and repeat the same things until you lose your cool and shout at them, this is what they want, so they can end the phone conversation and cut you off, then they log you down as a "difficult customer", which apparently I now am |
Fair enough |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Front crank seal is about 4 hours work |
I will phone them tomorrow and ask if front or rear crankshaft seal. |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Why didn't they do a smoke test, without the need to strip engine. One problem with Oil leaks is the Oil filter position, upside down in between the V of engine. Either the sitting right of seal or spillage when changeing oil. Then runs down engine and causes. Drips onto drive |
Update - Warranty Direct have turned down the claim as they say they do not cover a claim in the first 90 days if not already on warranty. I find this hard to understand in that I had several conversations with them and they knew the car was on dealer warranty until Dec 4th 2014 and they suggested I took out the Warranty Direct warranty in November so there was no lapse in service. They are now saying that they do not recognise main dealer warranty only manufacturers warranty for them to pick up warranty from day one of the policy. I was astounded.
Warranty Direct seem |
The warranty i got from my Indie Dealer, stated it did not cover Leaks ![]() |
Latest Update - I have argued with Warranty Direct the fact that I did indeed have a LR Extended warranty at the time of taking out my Warranty Direct warranty. Luckily I had the copy of the LR Headed warranty extension and therefore met the WD requirements of having a Manufacturers warranty at the time I purchased the WD warranty.
Dhups Member Since: 15 Sep 2013 Location: Essex Posts: 183 ![]() ![]() ![]() |
Good news... |
That's great news Nigel, and with the money you've saved, you should treat yourself to fitment and enablement of the remote function for the timed park heater. I can install and enable for you no problem |
