Home > General > Crankshaft Seal leaking -looking at £2,500 to repair!!
Page 2 of 3 <123>
Paddi
Good news indeed.
But the nerdy ones amongst us still want to know if it was the rear or front oil seal Rolling with laughter
Glad you are getting it fixed - fingers crossed there are no more leaks. 2008 MY Java Black TDV8 HSE
Post #448549 Thu Jan 15 2015 2:57pm
nigel52
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Dhups wrote:
Good news... Thumbs Up
I'm probably going to go over to warranty direct next year so good to know they should cover off a LR extended warranty.
before doing this make sure they will honour that agreement. After my fight they might try and change the wording.
Post #448556 Thu Jan 15 2015 3:36pm
nigel52
Paddi wrote:
Good news indeed.
Slightly confused feedback from the garage but what they said was it was the front crankshaft seal and new oil pump seal and sensor. Then they said it was the rear crankshaft seal but to get to the oil pump they had to renew a front seal???
They assure me that LR quote 15 hours for the whole job.
Hopefully when it is done I will get more information on the total job.
Was hoping that as they will have the car in till end of day next Wednesday they would have supplied a courtesy car but at the moment they say they do not have one - for such an expensive repair sort of thought they would supply one - they are looking for one.
Still -happy that warranty is picking up most of the cost.
Post #448557 Thu Jan 15 2015 3:41pm
nigel52
Bodsy wrote:
That's great news Nigel, and with the money you've saved, you should treat yourself to fitment and enablement of the remote function for the timed park heater. I can install and enable for you no problem Whistle Thumbs Up
Sorry Bodsy not something I can justify at the moment.
Post #448586 Thu Jan 15 2015 11:41pm
simple1
All smells slightly farmyard.
If a rear seal goes, no need to touch the front seal or pump so it seems they are doing some recall/enhancement work if they want to change these. Removing the gearbox and torque converter isn't a 15 hour job so as usual more questions than answers Big Cry
Am with you on the "why has it failed so early in life" question, have to say it's an unusual failure and don't think it's come up here since 2006 when I joined the forum. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #448615 Fri Jan 16 2015 10:21am
nigel52
When all completed I will try and get a copy of the bill and make it available to anyone who wishes to look at it.
Post #448623 Fri Jan 16 2015 11:58am
nigel52
Paddi wrote:
Good news indeed.
For Paddi and others that would like the details -here follows:
Job description: Crankshaft oil seal (rear) - oil pump seal and level sensor leaking.
This was interesting: Standard Hours - 7.70, Actual Hours 15.00. Labour rate: £105 plus VAT
When this was queried by Warranty Direct the following additional info was given:
Note: There are two jobs involved, the oil pump required the front of the engine stripping to replace and the level sensor requires the sump to be removed in order to get to. This is why the hours went from 7.70 to 15.00.
The final job broke down as follows:
Labour £1,575
Parts which included Timing Belt £423.36
Fluids ie oil £71.70
Total £2,070.06 plus VAT = £2,547.19
I am paying but WD have agreed to reimburse me less £50 excess and an oil filter circe £11.95 plus VAT
Hope that gives all the information everyone wants and that WD pay me back fairly quickly. Obviously pleased I followed the forum advice and took out the WD warranty. Even on a 3 yr old car only with 29,000 miles
Post #449416 Thu Jan 22 2015 8:08pm
Disco_Mikey
It sounds like the dealer has been having a quiet month Whistle
Post #449417 Thu Jan 22 2015 8:11pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
£105+vat per hour, Jeeze! I'm not Fat. RRS TDV6 HST.
Post #449418 Thu Jan 22 2015 8:26pm
Paddi
Thanks. Always good to hear the complete story. Great that WD are coughing up.
All that money just to fix a minor oil leak Shocked
Hope the TDV8 doesn't share the problem. 2008 MY Java Black TDV8 HSE
Post #449419 Thu Jan 22 2015 8:43pm
On a three year old car I'd be paying for LR's warranty. No worries about paying out and waiting for reimbursement then - they just do the work. Anyway, glad you got it sorted out in the end - does sound like a typical "make it up and see what we can get away with" approach from the dealership... 2012 SDV6 - it's missing a couple of cylinders
Post #449433 Thu Jan 22 2015 10:25pm
nigel52
I did not think LR Warranty covered wear & tear and for a crankshaft seal LR could say wear and tear that is why I went for WD cover and not LR cover.
Post #449440 Thu Jan 22 2015 11:35pm
nigel52
UPDATE - thought I would check my oil level after all the work done by the dealer and read out said 'overfilled' rang them up and they said leave over night and test again. Did this and still overfilled. Phoned them back and they said bring it in immediately. Took in in and had a two hour wait, one hour round trip drive. They took out 1/4 litre. No sorry or apology for wasting my time.
Whilst waiting asked the salesman who originally sold me the car for a price on the new Disco Sport HSE with electric memory seats. He tells me £34k. Just found out it is nearer £40k.
Getting less and less Impressed with. LR service and attitude.
Love driving the car but not the ownership experience.
Post #451671 Sat Feb 07 2015 10:17am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
. Take a deap breath, Sit down.How about £111.50 + £22.30 VAT =£133.80 Per Hour at Stratstones. Just paid £507.20 For Supply and fitting front Driveshaft they said 2 Hour job ? Had Fuel Gauge Modification done at same time,Paid for by Landrover. That also was supposed to be a 2 Hour job. They kept my car for a week. Now i have my car back,i have another problem that was not there when it went in. When driving accelerater goes dead,until i release and start again. I was wondering is this a case of, do a job, create a job? itisme
Post #451770 Sun Feb 08 2015 9:46am
harrygh60
nigel52 There are 4 models starting at SE £34,195, SE Tech £35695, HSE £39395, and the top of range HSE Luxury at £42995 These are Auto models manuals are about £1800 Cheaper Then add on paint, registration charge, Road Tax, Delivery Charge ETC. any goodies you may like And the price will rocket to around £47000 +
Me Too itisme
Post #451773 Sun Feb 08 2015 10:01am
Page 2 of 3 <123>
