![]() | Home > Technical > Electrically heated windscreen |
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
Normally de ices a heavily frozen windscreen in about 2-3 minutes.
wilburn Member Since: 09 Aug 2010 Location: Shropshire Posts: 82 ![]() ![]() ![]() |
Hmmm, ours is possibly broken, fingers crossed a blown fuse |
Check the connectors too, one either side of windscreen (behind A pillar trims I think) and might be a fuse for each side of heated screen. |
Thanks. I have just checked fuses as they are fine but they were both 15 amp not 30 amp as manual suggests. |
I have just started the engine and turned all electrics off after 30 seconds I turned the electric heated front screen on and I heard the engine note change slightly and the rev counter lowered by a mm or so. Then, when I turn the heated front screen off, the engine note changed again and the rev counter needle went up by a mm or so.
gwengler Member Since: 19 Aug 2013 Location: Toronto Posts: 19 ![]() ![]() |
There is a TSB out to replace the fuse. |
really? |
Here it is https://app.box.com/rrs/1/651893025/16311514903/1 .
Hmm, thats for MY2012, ours is a 2009, no idea why it has 15 amp fuses in it. They haven't blown on us despite being 1/2 what the manual says they should be.
