Home > Technical > Electrically heated windscreen
wilburn
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Im not 100% sure our electrically heated windscreen is working. I plan to wait for it to be frozen over one morning and start the engine, turn off the blowers and turn on the electric front screen and leave it to see if it thaws out.
In the past it has taken a while to deice, with blowers and heated front screen on.
Is the heated front screen quite powerful, i.e. will it quickly get rid of ice or is it more to help with the front screen not misting up whilst driving?
Post #444318 Thu Dec 04 2014 9:35am
Andi
Normally de ices a heavily frozen windscreen in about 2-3 minutes.
Just steam up the inside of windscreen, switch on windscreen heater and see if it clears
Post #444319 Thu Dec 04 2014 9:40am
wilburn
Hmmm, ours is possibly broken, fingers crossed a blown fuse Smile
A 'nice' icy morning will tell
Post #444320 Thu Dec 04 2014 9:41am
Andi
Check the connectors too, one either side of windscreen (behind A pillar trims I think) and might be a fuse for each side of heated screen.
Post #444323 Thu Dec 04 2014 9:58am
wilburn
Thanks. I have just checked fuses as they are fine but they were both 15 amp not 30 amp as manual suggests.
Post #444324 Thu Dec 04 2014 10:00am
wilburn
I have just started the engine and turned all electrics off after 30 seconds I turned the electric heated front screen on and I heard the engine note change slightly and the rev counter lowered by a mm or so. Then, when I turn the heated front screen off, the engine note changed again and the rev counter needle went up by a mm or so.
So it looks like it is working.
Post #444327 Thu Dec 04 2014 10:36am
gwengler
Canada
There is a TSB out to replace the fuse.
Post #444357 Thu Dec 04 2014 2:59pm
wilburn
really? Shocked
I could just replace them both myself with 2 x 30 amp ones if thats whats needed.
Post #444368 Thu Dec 04 2014 4:40pm
gwengler
Canada
Here it is https://app.box.com/rrs/1/651893025/16311514903/1 .
Gerd
Post #444371 Thu Dec 04 2014 5:48pm
wilburn
Hmm, thats for MY2012, ours is a 2009, no idea why it has 15 amp fuses in it. They haven't blown on us despite being 1/2 what the manual says they should be.
Shocked
Post #444372 Thu Dec 04 2014 5:51pm
