Home > In Car Electronics > Blackvue
Page 4 of 5 <12345>
PEACHY
ChrisP - mine was fitted by the same company - cannot praise them enough - very professional - very clean Thumbs Up
Peachy. 16MY Estoril Blue SVR.............
Post #439989 Mon Oct 20 2014 11:40am
ChrisP
Thanks Peachy,
I fancy the DR750LWHD,I'll give them a call,£180 sounds a bit heavy for the installation though Shocked
Cheers,
Chris MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #440006 Mon Oct 20 2014 1:11pm
PEACHY
TBH - I agree - but the fitting is guaranteed - done at your convenience - any trim removed is reinstalled with new clips - for that price you also get installed in the glove box another cut out switch that enables you to turn the system off if needed.
Add that to IMO a cracking service Smile its worth paying the cash. Thumbs Up 16MY Estoril Blue SVR.............
Post #440009 Mon Oct 20 2014 1:32pm
ChrisP
Thanks Peachy,
Just rung and he's quoted me £329.99 + £144.00 fitting but I forgot about the switch so not so bad really I guess and with a 64Gb SD card chucked in Thumbs Up
Off to Brighton in the hurricane tomorrow so will sort it when I get back and post some pictures.
Cheers,
Post #440010 Mon Oct 20 2014 1:45pm
jack.bauer
once installed, how discreet are these from opportunist smash & grabbers? 07 TDV8 + BAS map
Post #440553 Sun Oct 26 2014 10:32pm
It depends were you stick them
Mines up near the rear view mirror, sticky pad on the black dots, sort of just blends in looking like part of mirror setup from outside to me
Post #440556 Sun Oct 26 2014 11:08pm
PEACHY
This Censored never noticed it before robbing my spare wheel Twisted Evil & that blackvue was silver - my newer version is black & does blend in well.
Post #440579 Mon Oct 27 2014 8:32am
Mark1505
Location: Wales Home, Singapore work & Also many other parts of the world,
Wales 2007 Range Rover Sport TDV8 HSE Java Black
does anyone know how to format the 64Gb SD card, I put it the camera and says not recognised tried a format download that I got from the Blakveu website doesn't seemed to have worked. Java Black 2007 TDV8 HSE (my first RRS)
Colour coded door handles
Colour coded headlight washers
Smoked side repeaters
Hawk Colour coded side vents
Privacy Glass
Mud Flaps
Post #441434 Tue Nov 04 2014 12:28am
PEACHY
What make is the SD card ? - I have always used Scandisk with no issues. Sad The card formats when inserted into the Blackvue. Thumbs Up 16MY Estoril Blue SVR.............
Post #441441 Tue Nov 04 2014 7:30am
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Just a thought but what card format did you buy?
If it is a SDXC class card then it won't work in the Blackvue. SDXC uses exFAT file system not the FAT system needed by Blackvue which is supported by SDHC. cards
There are not many SDHC cards with a 64gb capacity, most high capacity cards tend to be SDXC
If you have the latest DR750 camera then it looks as though it is possible to convert the cards file system (see link). Not sure about other Blackvue models
http://blackvueshop.co.uk/news/?p=528
Post #441448 Tue Nov 04 2014 8:42am
Mark1505
Thanks peachy, all fixed now, when I put the card in it told me not recognised held the button in and card formatted, working well now.
Thumbs Up Thumbs Up Java Black 2007 TDV8 HSE (my first RRS)
Privacy Glass
Mud Flaps
Post #441604 Wed Nov 05 2014 6:47pm
PEACHY
Very Happy happy days Thumbs Up 16MY Estoril Blue SVR.............
Post #441608 Wed Nov 05 2014 6:57pm
Ady 555 wrote:
Not a bad bit of kit those MiWitness cameras.
http://www.amazon.co.uk/E-PRANCE-Original-...=mini+0801
did anyone invest their hard earned £40 in to a E-Prance dash cam
thinking of getting one to cover the rear
Post #442298 Wed Nov 12 2014 11:03am
Paulcp
I have one in my weekend car. The blackvue looked too bulky on the screen so I decided to try the mini 0801 since the price was good
TBH, for the price it is excellent and I have used it on the rear screen of the RRS. Video quality is good but there are 2 downsides
1. If you move it frequently the pins which attach to the base are a little fragile and the fit to the mount becomes a little loose
2. The early GPS versions, which the cheaper ones tend to be, have a problem with maintaining the set time. For some reason no matter what time you set it to, once the GPS kicks in the time defaults to the country of manufacture
Not sure if there is a firmware update to fix the GPS time issue, I haven't had the time to look. I fix it by setting the current time -3 hours so that it reads correct once the GPS starts up
Post #442349 Wed Nov 12 2014 5:34pm
Just bought this one for a permanent fit to rear screen
http://www.amazon.co.uk/dp/B00IKEVS6I/ref=...71_TE_item
Don't need GPS as Blackvue has that, and for £35 it's worth a punt Thumbs Up
Post #442355 Wed Nov 12 2014 7:09pm
Page 4 of 5 <12345>
