Home > General > Another TDV8, another turbo failure? |
Alex C Member Since: 09 Jun 2013 Location: Southampton Posts: 146 |
White smoke from the exhaust, could be head gasket rather than turbo?? Would a turbo failure not be black smoke with Unburnt fuel rather than white?
Thu Aug 07 2014 8:00pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9007 |
White smoke suggests that there is oil getting in to the exhaust stream after the engine which suggests, to me at least, that an oil seal has failed on the turbine side of the turbo. The last time I saw smoke like it was when an exhaust valve stem seal failed on a 309GTi - again, oil getting in to the exhaust stream after the engine so not fully burnt.
Thu Aug 07 2014 8:15pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Turbos are oil and water cooled as well as lubricated. Does sound like a turbo issue but could also be an injector which would also give white smoke. Three grand won't cover a right turbo, they are 1500 a side plus body off, the left can be done in situ. Fingers crossed it's not serious. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Aug 07 2014 9:58pm |
Well, if it's a few hundred over £3k then fair enough. At least they cover £3k. As you say - fingers crossed. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 07 2014 11:21pm |
mark.b Member Since: 02 Oct 2013 Location: cheltenham Posts: 113 |
Sorry to here your plight RRSTDV8 fingers crossed for you buddy its an injector |
Sun Aug 10 2014 8:28pm |
LR Assist, through Enterprise, gave me a RR Evoque SD4 for the weekend. Enterprise told me it needed to be back this morning however. Not that useful but better than nothing. Rang the garage who said that I should just keep it and they would sort it all out later. Enterprise were insistent that LR Assist had said 48 hours hire. Dropped it off first thing (as I didn't fancy paying a week's hire on an Evoque if they later denied knowledge of saying "keep it") and walked to the station to get a train to work.
Mon Aug 11 2014 12:46pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Hope your RRS is returned to you soon and the repair is permanent.
Mon Aug 11 2014 1:06pm |
I decided to pay the optional excess cover so my excess is £0. I know it's unlikely to be needed but... 2012 SDV6 - it's missing a couple of cylinders
Mon Aug 11 2014 9:12pm |
Sensible. This is what I have done with my ZipCar account as well following the Enterprise event. |
Mon Aug 11 2014 9:40pm |
The fact that production run was limited to three years effectively is proof enough that LR had issues with this car. Five turbos in six years happens for a reason and suspect you had recently parked your car up for a few days prior to failure? Glad it's on way to being sorted and hope you don't fall for Evoque.
Tue Aug 12 2014 7:30am |
No, vehicle had been used everyday for a while preceding the failure. I suspect that the RRS engine bay is just too small for the TDV8 and the cooling is possibly not as good as it might ideally be. After all, the TDV8 and SC both have an additional cooling radiator to try to keep the engine cool. The SC doesn't have two hot turbos nestled low in the bay though. I've never had an overheat issue on the vehicle, as far as I am aware, so it's just my hypothesis that cooling is the issue. 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 12 2014 7:59am |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
There are many TDV8's that have done lots of miles without problems but this engine variant does seem to have a weakness for eating turbo's. Does anyone have a theory or advice for how to avoid turbo problems, apart from not letting them stand for more than a few days?
Tue Aug 12 2014 8:03am |
I forgot to mention, my sincere sympathies also to RRSTDV8. Even if covered by warranty it's not a nice thing to happen. |
Tue Aug 12 2014 8:05am |
My failures always took place after car had been parked up for week or more, the first when it sat at dealers for six weeks waiting for new dash. The last after three weeks at Heathrow carpark
Tue Aug 12 2014 8:21am |
