![]() | Home > General > Another TDV8, another turbo failure? |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Glad to hear your RRS is being sorted and without it hurting your wallet. Thank goodness for the warranty. |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Ady 555, in a previous life I used to let the turbo's cool with tractors and big excavators but I don't do this with the RRS. Do you reccomend something like 2 or 3 minutes at tickover before stopping the engine? |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Under bonnet temperature could be an issue - I recall donkey's year ago while working on military vehicles we'd installed the Jag 6cylinder (i.e. 4.2, E-type) engine in some lightweight (for a Tank) vehicles and cooling was a big factor - it contributed to all manner of problems including warped cylinder heads etc. Everything tends to be OK while the engines is running and the vehicle's in motion its a few minutes after stopping that the real issues can start.
Always cautious when cold and let turbos cool for 30 secs, or time it takes to gather fags, phone, case and other clobber that gathers on front seat ![]() ![]() Audis suffered from under bonnet hot spots but quickly resolved the problem by installing afterun pumps to keep water flowing, issue with turbos is that they revolve at 18000 rpm at tickover, so cutting oil supply to them when switching off isn't helpful but majority of manufacturers have protection systems. The introduction of sulphur free diesel is major factor in build up of soot and carbon, the EGR system in quest to reduce immissions is another detrimental factor to engine long life. 2x TDV6. SE and HSE. Both returned to sender with issues👀 TDV8 Sport HSE...... Gone. Loved it but it didn't love me!! Now rolling in MY10 Fullfat TDV8 Vogue. Slammed it to go round corners🙈 Cruising daily #56 mph in a Volvo V8. 😱 Lots of other toys in the cupboard...😜 |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 552 ![]() ![]() |
Hi ,
Sporting Chance Member Since: 08 Aug 2013 Location: Oxford Posts: 32 ![]() ![]() ![]() |
I always let mine after run. I also let it warm up and I think this is just as important from a cold start. I let it idle for a few minutes when I start it for the first time that day, even if it's a warm summers day. Got to let the oil get round before getting the revs up. Jim Current 2010 RRS TDV8 Gone 2009 D3 HSE TDV6 Gone 50th anniversary Defender Gone 1992 Defender 200 TDI Gone 1988 Defender TD Gone 1979 Series 111 V6 Steve Parker conversion |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
Yes, garage phoned today to confirm warranty covering it. Phew! ![]() I'm actually enjoying the Evoque - could see one as a second car on the drive. Shame SWMBO isn't a great fan! ![]() 2008 TDV8 - it was a labour of love and is much missed |
Garage phoned to say that it won't be ready until Monday PM. Apparently they are going to replace both turbos! They're struggling with them too, according to the service chap.
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
Sounds like a good result. I noticed you said you had taken out this years warranty with extended version, what is this? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5061 ![]() ![]() ![]() |
Basic Differences
Thanks Col. |
As shown by Col, there are two versions of LR's warranty. They've recently changed the thresholds for the two types. Previously, the Extended cover was limited to 7 years old / 100k miles. This year they have allowed it to cover vehicles up to 10 years/100k miles. Last year I had to go on to the Select (lower cover) but this year I changed back to the better cover. And I'm glad I did!
Hi yeah I was surprised at renewal price as I'm sure it's same as I paid last year, but then didn't make any claims so as you suggest might be a factor.
Do you go direct or via your dealers? |
