Home > In Car Electronics > screen default to 'off'?
Mark_TDV8
England 2007 Range Rover Sport TDV8 HSE Cairns Blue
Afternoon,
This may sound like an odd request, but does anyone know if you can get the screen in the dash to default to off when you turn the car on - it is an '07 TDV8 HSE with rear entertainment if that makes any difference.
As a rule I don't need the nav to drive to work or to tescos, so I really only want the screen to come on when I want to use the features it offers. in normal ioeration I would like it to be off.
I havent managed to find a setting to get it to do it, so I wondered if it was a vehicle setting...
Mark 2007 TDV8 RR Sport HSE
2003 TD5 Discovery 2 ES
2001 TD5 Defender 110 DCPU
2003 4.4 RR Vogue [Project]
Post #416258 Mon Mar 03 2014 11:45am
mse
Personally I don't know why you would want it off - there is a fair amount of info on it and its not intrusive...but all you can do is turn the screen off using the button on the main home screen Mike
2014 Facelift Discovery
Post #416368 Mon Mar 03 2014 6:58pm
Mark_TDV8
Mike,
Maybe I am missing something then? which screen do you have it on during normal everyday driving?
Post #416461 Tue Mar 04 2014 9:51am
MAW
I think mine (MY12) comes on on the screen it was turned off on...
Post #416463 Tue Mar 04 2014 10:02am
MAW
...So on the audio menu most of the time ....
Post #416464 Tue Mar 04 2014 10:03am
Mark_TDV8
I don't have an Audio Menu on my '07...
I have Nav, 4x4 Info, Rear entertainment, Settings, TV and DVD - None of which are especially useful when I know where I am going, am on my own, and driving on normal roads...
I guess I can turn the brightness right down, but I wondered if it could default to 'off' unless required.
Post #416471 Tue Mar 04 2014 10:34am
mav101
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
yes its a very good question... usually the first thing i do after starting is turn the screen off
Post #416484 Tue Mar 04 2014 11:35am
SimonR
I don't have an answer either - but agree it would be useful! I find, even on min brightness, the screen is a bit bright driving on unlit country lanes where you need all the night visibility you can get!
Since I switch the screen off except when I'm using the sat-nav - it would be nice to default to it being off!
Si
Post #416485 Tue Mar 04 2014 11:51am
mse
I didn't realise yours was an 07...11My and 13My had it sorry, Mike
Post #416544 Tue Mar 04 2014 5:16pm
Bob.
I belong to the "I wish I could turn it off and it stays off until I turn it on group",
but I also belong to the "I wish I could turn off the annoying bong if the ignition key is in and the driver's door is open" group
plus the "why can't I put it into gear without being treated as an idiot and having to put my foot on the brake first" group
and then there's the " why do I have to agree to a set of Ts & Cs which no one reads when I want to use the satnav" group.
There are a few others but I feel a bit better now so I will stop Laughing
Seriously Mark after 5 years of an 07 TdV8 I haven't found a way of turning the screen off other than via the Settings screen.
Post #416597 Tue Mar 04 2014 9:10pm
mse
Again MY14 on the accept screen has now gone (well its automatic at the very start) and there is no key.
The foot on the brake thing is there...but its there for other reasons rather than because we are treaded as fools. Mike
Post #416645 Wed Mar 05 2014 8:25am
Mark_TDV8
I thought all automatics required the foot on the brake o move out of park? pretty much all the ones I have driven has been the same. 2007 TDV8 RR Sport HSE
Post #416647 Wed Mar 05 2014 8:48am
mse
Yes in part its to enable the solenoid to release to allow the gear change Mike
Post #416676 Wed Mar 05 2014 12:36pm
Bob.
Foot on the brake to get out of Park was introduced around 2004 by LR IIRC. It was intended as a safety measure to avoid unintentional reversing (if the handbrake was not on or the engine was revved) or movement on accidental selection of a gear. It is now an integral part of stop/start systems.
Post #416775 Wed Mar 05 2014 9:56pm
