![]() | Home > In Car Electronics > screen default to 'off'? |
Personally I don't know why you would want it off - there is a fair amount of info on it and its not intrusive...but all you can do is turn the screen off using the button on the main home screen Mike
Mark_TDV8 Member Since: 17 Nov 2013 Location: West Sussex Posts: 42 ![]() ![]() ![]() |
Mike,
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I think mine (MY12) comes on on the screen it was turned off on... |
...So on the audio menu most of the time .... |
I don't have an Audio Menu on my '07...
mav101 Member Since: 22 Jan 2013 Location: Bromyard Posts: 28 ![]() ![]() ![]() |
yes its a very good question... usually the first thing i do after starting is turn the screen off |
SimonR Member Since: 29 Sep 2013 Location: Horsham Posts: 25 ![]() ![]() ![]() |
I don't have an answer either - but agree it would be useful! I find, even on min brightness, the screen is a bit bright driving on unlit country lanes where you need all the night visibility you can get!
I didn't realise yours was an 07...11My and 13My had it sorry, Mike
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
I belong to the "I wish I could turn it off and it stays off until I turn it on group",
Again MY14 on the accept screen has now gone (well its automatic at the very start) and there is no key.
I thought all automatics required the foot on the brake o move out of park? pretty much all the ones I have driven has been the same. 2007 TDV8 RR Sport HSE
Yes in part its to enable the solenoid to release to allow the gear change Mike
Foot on the brake to get out of Park was introduced around 2004 by LR IIRC. It was intended as a safety measure to avoid unintentional reversing (if the handbrake was not on or the engine was revved) or movement on accidental selection of a gear. It is now an integral part of stop/start systems. |
