Home > Maintenance & Modifications > Rear pads to be replaced
steve-r
Wales 2007 Range Rover Sport TDV8 HSE Java Black
Well seeing as my battery decided to go flat I still haven't had chance to sort this wee problem out, but I defiantly won't be joining the 2 wires together Laughing
Post #410814 Thu Jan 23 2014 5:47pm
Black Bess
Do that, and you will never need to worry about pad wear again.... Very Happy Very Happy Very Happy
Post #410941 Fri Jan 24 2014 1:22pm
drdelrrs
but next time you hear the noise and need pads you'll need a disc as well Thumbs Up
Post #410949 Fri Jan 24 2014 2:00pm
Daddyjcool
In my defence, this is the first car I've owned with brake pad sensors, so I'm used to checking the wear myself. In the same way, I don't wait until the 'low oil light' comes on to warn me the oil's running low, I check that myself too.
j
Post #411016 Fri Jan 24 2014 10:35pm
steve-r
I always thought that if the low level light came on then it's a bit to late, (this is coming from my zed cars) that if light comes on then the oil is empty not low, thus causing more damage. Surly oil should be checked on a weekly basis and not assume the waring light will come on. Thumbs Up
Post #411093 Sat Jan 25 2014 7:51pm
flack
@steve-r
It sounds like you have lost the little brass/copper spring that holds the sensor in the pad if its a loose fit in it. They sometimes spring out and you don't notice.
Flack Thumbs Up
Post #411101 Sat Jan 25 2014 8:42pm
LOCUST
Ive had my front pad sensors come on and they seem to be no where near needing changing.. but the sensor has work through so im a bit miffed there..
Post #411414 Tue Jan 28 2014 7:21am
steve-r
flack wrote:
@steve-r
Flack Thumbs Up
Is the spring a separate part then? i assume this doesn't come with the new sensor? if not then oh Censored Sad
I cant say i noticed any kind of spring fitting, but then again wasn't really looking for any thing like that.
Post #411465 Tue Jan 28 2014 1:15pm
steve-r
yeehaa, found the problem it was me a ham fisted muppet, when pushing the male connector into the female connector, I managed to bend one of the small pins Embarassed
Post #411645 Wed Jan 29 2014 4:52pm
