Home > Maintenance & Modifications > Rear pads to be replaced
steve-r
Wales 2007 Range Rover Sport TDV8 HSE Java Black
Just a quick question, when I replace my rear pads (tdv8) will the pistons just push back into the caliper or do they work like a thread type piston and a special tool required?
LR wanted over £280 to replace these, I nearly fell over when they said that Shocked
Post #409144 Sat Jan 11 2014 7:26pm
Paddi
You just push them in they are regular calipers. Its a very easy job. Dealers are robin barstewards Rolling Eyes 2008 MY Java Black TDV8 HSE
Post #409152 Sat Jan 11 2014 8:50pm
Bodsy
Site Sponsor
Use the bible Whistle Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #409156 Sat Jan 11 2014 8:55pm
steve-r
Cheers paddi Thumbs Up
@ bodsy I looked at the bible, but being a bit of a tard newb, wasn't sure if RRS used the same as the disco's. Embarassed
Changed a few pads in my wee life time (on numerous cars) and you often find there always some subtitle little difference between models . Going to have to order me a set and have a bash at these next weekend.
Ta mucho
Post #409168 Sat Jan 11 2014 10:34pm
SRE
Spain
Simple, just push them back, however I would open the bleed nipple first, that way you dump the dirty used fluid, you don't push it back towards the master cylinder Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #409198 Sun Jan 12 2014 10:17am
Paddi
Ta mucho
At the rear, exactly the same as the Disco3. Thumbs Up 2008 MY Java Black TDV8 HSE
Post #409202 Sun Jan 12 2014 10:29am
steve-r
Brill, and thanks for the nipple advice, I would have just pushed pistons back Thumbs Up
Post #409207 Sun Jan 12 2014 11:16am
steve-r
Well managed to change the rear pads today and no problems apart from a warning light now on dash saying check pads. I have replaced the sensor and not sure if this has connected properly. I found that the sensor on the actual pads not to be a nice snug fit.
The sensor seems to be quite lose to touch but I'm sure it's pressed home properly. Does the sensor have to be firm to the touch ( with no wobble) or could the pins on the connector be the problem, or is there something else silly I'm missing. I have also tried leaving key in position 2 (no engine running) for approx 45s , to see if this helped with a reset, but alas no joy Sad
Post #410073 Sat Jan 18 2014 7:14pm
LOCUST
i had my check break pad light come on, went to change pads today to find there completly fine......
and my light is on !! so annoying.. so will check the fronts tomorrow
Post #410074 Sat Jan 18 2014 7:22pm
steve-r
My fronts are fine, but rears had about 2-3mm left on them, new pads new sensor new warning light ...bummer
Btw my light wasn't on before I changed pads and sensor
Post #410075 Sat Jan 18 2014 7:25pm
Black Bess
I think you need to check the warning light sensors and possibly fit new. They should be a positive fit by the way, but old ones get brittle and really need replacemnt everyt time with the pads. The sensor wire conections above the chassis in each wheel arch can be a bit fiddly to do.
btw, on my car, there was a spare jackplug hanging in the breeze up there (not sure what it is for) and working blind, I tried to connect to the wrong one. Might be worth having another look.
Adam..
Post #410305 Mon Jan 20 2014 12:54pm
Paddi
It's the unused loom connector for the TPMS - which you don't have. 2008 MY Java Black TDV8 HSE
Post #410309 Mon Jan 20 2014 1:14pm
Black Bess
Hey thanks Paddi.
That is good to know.
Cheers, Adam..
TPMS will be mandatory on new cars soon. Talk about a sledgehammer to crack a nut. Why not just check your tyre pressures regularly?
Post #410312 Mon Jan 20 2014 1:22pm
Daddyjcool
I managed to damage the brake wear sensor when I changed the rear pads, so just stripped the two wires back & tied them together.
No more brake pad warning light Surprised
J
Post #410791 Thu Jan 23 2014 3:16pm
Paddi
Shame on you that's a bodge Rolling with laughter
New one is only about a fiver so fix it properly. 2008 MY Java Black TDV8 HSE
Post #410810 Thu Jan 23 2014 5:30pm
