![]() | Home > In Car Electronics > Missing AUX Audio Port |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Should be a little plastic flap on the back of the centre console. Just flap it down and behind it should be an aux socket and 12v socket |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
I think it was only standard on HSE & HST models and an optional extra on the SE & S models. 2014 L405 SDV8 RR Autobiography |
PeterHorten Member Since: 23 Sep 2013 Location: Innsbruck Posts: 15 ![]() ![]() ![]() |
Thank you.
Here is a detailed thread on the Disco3 forum which shows how to retrofit AUX input:
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 ![]() ![]() |
I am going to hunt down and buy the aux port and 12v power socket and give it a go as the data cable and power lead are behind the blank on my Australian spec 2005 RRS. |
I have now bought and installed the correct aux port and power socket using the pre-existing leads behind the previous blank, however I do not get any sound from the aux input on the stereo.
Still no sound after checking Aux input with IIDTool (already enabled) so I guess I am going to have to pull the head unit to ensure the cables are connected at that end.
