Home > In Car Electronics > Missing AUX Audio Port
PeterHorten
Austria 2007 Range Rover Sport TDV6 SE Zermatt Silver
I have a 2007 Range Rover Sport SE and can't find the Aux Audio port. It's not on the back of the centre console. One the back is some sort of a blanking plate.
The head unit has an Aux button, which you can select.
Any ideas? Thank you..
Post #399052 Sat Oct 19 2013 6:59pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Should be a little plastic flap on the back of the centre console. Just flap it down and behind it should be an aux socket and 12v socket
Post #399057 Sat Oct 19 2013 7:33pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
I think it was only standard on HSE & HST models and an optional extra on the SE & S models. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #399058 Sat Oct 19 2013 7:38pm
PeterHorten
Thank you.
Do you think that there is a blind cable or that itīs possible to lay a cable? The jack would not be the problem.
By the way: Has the head unit in this case an aux port?
Post #399062 Sat Oct 19 2013 8:01pm
JasM
Here is a detailed thread on the Disco3 forum which shows how to retrofit AUX input:
http://www.disco3.co.uk/forum/topic68458.h...+ipod+lead 2014 L405 SDV8 RR Autobiography Cool
Post #399074 Sat Oct 19 2013 10:11pm
idrabble
Australia
I am going to hunt down and buy the aux port and 12v power socket and give it a go as the data cable and power lead are behind the blank on my Australian spec 2005 RRS.
Post #402355 Sat Nov 16 2013 5:23am
idrabble
Australia
I have now bought and installed the correct aux port and power socket using the pre-existing leads behind the previous blank, however I do not get any sound from the aux input on the stereo.
I am waiting for an IIDTool to arrive and I see in the list of CCF functions for the 2005 RRS an option for Aux Input, will enabling this be all that is additionaly required?
Post #405034 Fri Dec 06 2013 6:53am
idrabble
Australia
Still no sound after checking Aux input with IIDTool (already enabled) so I guess I am going to have to pull the head unit to ensure the cables are connected at that end.
Any tips?
Post #405659 Wed Dec 11 2013 12:20am
