Home > In Car Electronics > Missing AUX Audio Port |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
Should be a little plastic flap on the back of the centre console. Just flap it down and behind it should be an aux socket and 12v socket |
Sat Oct 19 2013 6:33pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
I think it was only standard on HSE & HST models and an optional extra on the SE & S models. 2014 L405 SDV8 RR Autobiography
Sat Oct 19 2013 6:38pm |
PeterHorten Member Since: 23 Sep 2013 Location: Innsbruck Posts: 15 |
Thank you.
Sat Oct 19 2013 7:01pm |
Here is a detailed thread on the Disco3 forum which shows how to retrofit AUX input:
Sat Oct 19 2013 9:11pm |
idrabble Member Since: 25 Oct 2013 Location: Brisbane Posts: 61 |
I am going to hunt down and buy the aux port and 12v power socket and give it a go as the data cable and power lead are behind the blank on my Australian spec 2005 RRS. |
Sat Nov 16 2013 4:23am |
I have now bought and installed the correct aux port and power socket using the pre-existing leads behind the previous blank, however I do not get any sound from the aux input on the stereo.
Fri Dec 06 2013 5:53am |
Still no sound after checking Aux input with IIDTool (already enabled) so I guess I am going to have to pull the head unit to ensure the cables are connected at that end.
Tue Dec 10 2013 11:20pm |
