Home > General > Lowering electronically |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Can someone give me any info regarding the amount of adjustment on the air suspension (2012 model) using one of the lowering modules like the GAP unit. Is it right that if you go lower by more than 15mm or something then the suspension throws a wobbly.
Wed Nov 13 2013 8:58pm |
Found info on another thread, but thanks anyway for looking MY16 AUTOBIOGRAPHY Indus silver with some toys
Wed Nov 13 2013 9:43pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
I have a LLAMs system fitted and drive around with the cars system set to on road height and LLAMs set -20mm. Drives fine no issues at all.
Thu Nov 14 2013 1:56am |
Hi Gordon,
Thu Nov 14 2013 2:38am |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Same here.
Thu Nov 14 2013 8:42am |
Usually the extended suspension message only comes in if you lower more than 25mm (on flat ground)
Thu Nov 14 2013 2:04pm |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
That's not as good as the full fat then.
Thu Nov 14 2013 2:56pm |
Only via a unit Darren
Thu Nov 14 2013 3:24pm |
Hmmm not sure I'd pay for a unit to do it then if then when I park and put it into access mode it throws a fault code up. |
Thu Nov 14 2013 8:00pm |
Wouldn't want faults of any sort, never mind paying for them MY16 AUTOBIOGRAPHY Indus silver with some toys
Thu Nov 14 2013 8:53pm |
No fault codes here '08 RRS TDV8
Thu Nov 14 2013 11:08pm |
The messages are not faults - they are simply messages telling you what is going on. 07MY RRS TDV6
Thu Nov 14 2013 11:57pm |
Ok! No faults , that's good. So those that have a lowering unit, what amount can you lower the suspension and still have an good ride quality ? MY16 AUTOBIOGRAPHY Indus silver with some toys
Fri Nov 15 2013 1:15am |
As I indicated above I run mine at -20mm (is just a flick of a switch to change from onroad height to -20mm, or +30mm or +50mm) and the ride is the same as at onroad height, no change in tyre wear, no need to do a wheel alignment.
Fri Nov 15 2013 1:21am |
