![]() | Home > General > Lowering electronically |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Can someone give me any info regarding the amount of adjustment on the air suspension (2012 model) using one of the lowering modules like the GAP unit. Is it right that if you go lower by more than 15mm or something then the suspension throws a wobbly.
Found info on another thread, but thanks anyway for looking |
I have a LLAMs system fitted and drive around with the cars system set to on road height and LLAMs set -20mm. Drives fine no issues at all.
Hi Gordon,
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Same here.
Usually the extended suspension message only comes in if you lower more than 25mm (on flat ground)
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
That's not as good as the full fat then.
Only via a unit Darren |
Hmmm not sure I'd pay for a unit to do it then if then when I park and put it into access mode it throws a fault code up. |
Wouldn't want faults of any sort, never mind paying for them |
No fault codes here '08 RRS TDV8
The messages are not faults - they are simply messages telling you what is going on. 07MY RRS TDV6
Ok! No faults |
As I indicated above I run mine at -20mm (is just a flick of a switch to change from onroad height to -20mm, or +30mm or +50mm) and the ride is the same as at onroad height, no change in tyre wear, no need to do a wheel alignment.
